August 25, 2025, 01:34:09 AM *
Author Topic: The Right Size Mags to use ????  (Read 13136 times)
FE 4 ME
"A Sweet Sensation"
« on: August 03, 2011, 07:48:30 PM »
Hi there my Holden mates,
  Can anyone tell me what is the max. rim ( mags ) size and tyre width i can put on my FE without causing rubbing or dramas ?
any advise would be a great help
thankx
"Have A Great Holden ( FE ) Day !!! SmileySmileySmiley
FE 4 ME
Stewy
sa-club
Jeff Stewart
« Reply #1 on: August 03, 2011, 08:16:53 PM »
Hi FE 4 ME,
You might need to be a bit more specific with your setup.
If you are going standard kingpin front end with drum brakes,
or ball joint with disc. Standard rear end or not?
I cant help with sizes, but you can never have to much info.
Cheers Stewy   Cool
FE 4 ME
"A Sweet Sensation"
« Reply #2 on: August 03, 2011, 08:21:25 PM »
Thankx Stewy...
   ive got a HR Disc front end and i assume a standard rear drum brakes...i was hoping maybe 14" mags would go on without rubbing on standard gaurds
Hope that helps
FE 4 ME
« Reply #3 on: August 03, 2011, 08:58:42 PM »
I've got a HR front end, LH discs and calipers, HR Banjo rear.
HK rims front with 185/50 tyres, and rear modified HK rims 14x8 235/60 tyres.
FE 4 ME
"A Sweet Sensation"
« Reply #4 on: August 03, 2011, 09:09:24 PM »
Thankx Stinky,
   so 14" mags fit ok, now when im on the hunt for alloy mags i can at least throw 14" into the mix, we all know how hard this type of stud pattern mags are to find..
FE 4 ME
« Reply #5 on: August 03, 2011, 11:29:08 PM »
The stud pattern is easy enough to find if you look, there is post elsewhere on cars that share the early holden PCD.
Watch the offsets and tyre sizes too. The bigger the mag the smaller the profile tyre needed to keep the diameter the same, there are online calculators that can work this out for you.
FE 4 ME
"A Sweet Sensation"
« Reply #6 on: August 04, 2011, 02:37:34 PM »
Yet again you have helped me Stinky with your advise, is there a website you know of that has these calcs ? also what offset would my front and rears have Stinky ??
thankx again and thankx in advance
FE 4 ME   Grin
« Reply #7 on: August 04, 2011, 03:08:08 PM »
You'll need to determine your own required off-set sorry. Start with a wheel that fits and then get measuring.
Here's a link to a tyre size calculator - http://www.miata.net/garage/tirecalc.html
Ol_Girl_58
getting there...
« Reply #8 on: August 04, 2011, 03:57:57 PM »
FE 4 ME
"A Sweet Sensation"
« Reply #9 on: August 04, 2011, 05:38:06 PM »
Thankx guys for your help, info, diagram and web link...i'm sure i can take it from here  lol Tongue
while the 13" rims are on the car i will make measurements than take them off and measure the offset of the rims, than i can determin what i can look out for in conjuction with the information diagram and link i should be well informed
i'm sure this thread and your helpful information will help many of us who are on a very fast learning curve
"Have A Great Holden ( FE ) day !!!" SmileySmileySmiley
FE 4 ME
fink fc
« Reply #10 on: August 04, 2011, 05:44:14 PM »
DON'T FORGET YOUR RIDE HEIGHT.IF THE F/END HAS BEEN LOWERED 14S MAY BE A HASSLE. Cool
Hobbo
« Reply #11 on: August 05, 2011, 10:05:45 AM »
Hi fellow Fe/Fc lovers, I also am chasing mags for my Fe, I can get Volvo 15x6.5 factory mags at the right price, does anyone know if they will fit and clear the front guards etc? I have std HR disc brake front end with EH diff and rear brake drums. The tire choice and price is much better than 13' !
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« Reply #12 on: August 05, 2011, 01:13:16 PM »
14 x 6 and dropped 1"  - just touch at the rear with heavy bums on seats - HR disk front, drum rear
13 x 7 and dropped 2" - massaged the rear guards standard front and rear
regards
Weddo
MAF
« Reply #13 on: August 08, 2011, 11:30:26 PM »
Hi FE 4 me
I have 2 sets of mags that Fit the Fc I have, 1 set of drag ways and 1 set of 5 slot. I plan on getting rid of both sets if your interested.  Let me know and I'll send you some pics.
MAF
Hobbo
« Reply #14 on: August 09, 2011, 12:48:48 PM »
Hey MAF, where are you? SA I hope? I might be interested in those mags.
perth_ute
« Reply #15 on: August 15, 2011, 02:21:36 PM »
running with out any issues and past WA licensing:
Front - HR front end with HR disc - 15x6 and 205x55x15
Rear - HR diff with drum brakes - 15x8 and 225x50x15
paddyfc58
I wanna go fast
« Reply #16 on: August 15, 2011, 05:05:40 PM »
Hi perth_ute
What type of mags, is it lowered, any pics
thanks
Paddy
Simo
« Reply #17 on: August 15, 2011, 08:06:28 PM »
Hey MAF
What size are the mags you want to sell mate?
Simo
perth_ute
« Reply #18 on: August 16, 2011, 11:03:52 AM »
have a couple of pics in the projects folder. Using pursuit rims, about 20-50 each then had the center changed to HR stud pattern and the offsets changed along with the width for 70 each. Tyres were 150 front and 220 rear. Hope that helps! The ideas was a cheap man's drag way solution until more funds. I think dragway pro-lite would be about 1400 for a set. It looks great with 15 and my opinion keeps the ages of the car.
paddyfc58
I wanna go fast
« Reply #19 on: August 16, 2011, 08:33:47 PM »
Am currently looking at these
http://wheelpros.com/brand-wheels/?groupid=64
vn405 custom tourque last one bottom right Cool
Page created in 0.036 seconds with 21 queries.
