July 24, 2025, 05:24:16 AM *
Author Topic: tailgate lock disassembly, how do I? - I need to get it rekeyed.  (Read 2919 times)
MikeM
« on: July 27, 2011, 09:21:36 PM »
Good evening everyone,
Can anyone help me understand how I remove the physical lock from the tailgate handle on my wagon? I have taken it to a locksmith and they advised they couldn't get the lock out to re-key it.   I have taken the small pin out from 3/4 way down the handle (the squarish and bigger "pin" is still in).  The lock does move slightly side to side in the T piece housing (for a fortnight I have been using WD40 and light tapping on a wooden block although I am pretty sure it was moving before anyway) but the lock itself wont come out.  I know that for the ignition I have to turn it past lock and use a pin to pop the lock however the tailgate doesn't work like that and I cant lock or unlock it without a key anyway - I am not even sure if it is locked or not at the moment although I have been able to open the tailgate (I know how stupid that sounds but maybe it is just broken Smiley.
Any suggestions/experience anyone can share with me on how I might be able to fix this?
Mike
« Reply #1 on: July 27, 2011, 10:57:55 PM »
Mike, your tail gate key should be the same as your ignition, glove box and door key, so whatever key code, usually 4 digits that are stamped on any of the other lock barrels in the car should be the correct key to unlock / lock it
If you don't have a key already, take the code number to a proper dedicated locksmith and he should be able to look up the code in his big black book and cut a key from the code
Gary
« Reply #2 on: July 28, 2011, 07:35:02 AM »
Gary
[/quote]
Or just punch the code in to the computer operated key cutter and presto  Grin Grin Grin Grin.......FC427......
