September 08, 2025, 11:17:28 AM *
Author Topic: twin carb linkage  (Read 2754 times)
Jonno
« on: May 29, 2011, 06:34:52 PM »
I wonder does anyone have any pictures of the connection between a twin carb setup and the standard throttle linkage?
I've been puzzling over this for a while now. It seems to me that it is not very easy to convert the motion of the standard throttle linkage (which moves down and toward the firewall) with that required for a twin carb manifold (the movement required being at 90 degrees to the above but also not directly above the throttle lever). Not clear how this can work without a lot of slop in the linkage. Any advice most appreciated.  Or do you just go over to a cable setup?
cheers, Jon
Cottles Bridge, VIC
Glen
« Reply #1 on: June 09, 2011, 06:08:35 PM »
I fitted twin BXUV2 carbs straight off an X2 HD on my FC years ago now. I remember that even after making little brackets and things to set it up, I found that the standard FC throtle linkage didn't have the torsional rigidity to fully open them. (just could not get full throttle) I played around a fair bit (spring rates etc) before I threw the hands up and went for a HZ pedal and cable arangement that most guys at the time were doing. Works well. Would be happy to post some photos if you can wait a few weeks.
Jonno
« Reply #2 on: June 09, 2011, 09:01:24 PM »
thanks Glen....I'm coming around to the same conclusion too....the angles just don't seem quite right.
Cottles Bridge, VIC
