August 25, 2025, 12:23:33 PM *
Pages: 1 [2] 3   Go Down
Author Topic: Holden FE ute fitting a 253  (Read 36255 times)
perth_ute
« Reply #20 on: March 11, 2015, 04:21:12 PM »
Scary looking at the last time I updated this thread but have been very busy getting it completed in the last 12 months.
« Reply #21 on: March 11, 2015, 05:33:28 PM »
well I don't see any photographic evidence  Huh
Stash
Sydney, NSW
johnchaplin
« Reply #22 on: March 11, 2015, 10:00:58 PM »
Some photos would be great
FireKraka
« Reply #23 on: March 12, 2015, 11:40:48 AM »
I'm with the other guys lets see some photos and have you had an engineer have a look yet?
Neil H
perth_ute
« Reply #24 on: March 12, 2015, 04:19:52 PM »
I have completed the mechanical side
front end completed with HQ front brakes, HT booster, custom cross member and alloy radiator.
Lots of updates but will list the horror and and positive.
The 253 and 4 speed all fits. Went to start after sitting for a couple of years and it just would not start. After grabbing a cool drink the investigation started. Found the fuel had separated with water going to the carby. Drained the fuel tank and carby and went to start again. It then got good fuel and massive back fire which was caused by the dizzy being 180deg out. Then it started but very rich. Huge amounts of black smoke was caused by power jet in the carby being damaged from the back fire. Then it started and allowed to settle but it blew a welsh plug. After drinking most of the cool drink from the fridge now and removing the engine changing all welsh plugs and fitting it, she now runs and idles.
Called around Perth for a radiator and was shocked by the quotes. I bought an alloy rad with spal twin fan fit and hidden overflow from group in Vic.
radiator
Painted the custom cross member
Brakes
perth_ute
« Reply #25 on: March 12, 2015, 04:27:50 PM »
But some horror. After mechanically working I pulled it all apart and sent it to a shop in Malaga (Reaper Ripoff Customs) to have the frame holes filled, radiator cutouts welded, and firewall smoothed.
I went there after one day and this was the result.
firewall horror
ps horror
frame horror
perth_ute
« Reply #26 on: March 12, 2015, 04:43:09 PM »
So I cancelled the job and picked it up but first was billed the full job.
You have been warned!!!!
Ordered a new gearbox tunnel to get fitted.
new tunnel
Noticed that Ripoffs have warped the front frame so spent 4 months on weekend getting it to fit again.
front frame repaired
Found a welder and painter JC. He recommended the body and jams gets sandblasted to ensure a perfect job. So the parts such as spare tyre door, door hinges, and tray side panels to name afew were done first. Next was the main body, panels, interior were done. Really happy with sand blasters job and no damage.
before
off she goes
after
su3prises
From the sand blaster it went to JC all the way north to Bullsbrook. Will post progress of welding and paint.
VAN059
Brisbane, QLD.
« Reply #27 on: March 12, 2015, 06:00:38 PM »
The utes body isn't too bad, perth_ute. Shame about the panel shop  Angry
Where did you get the cross member? Fabricate yourself?
Keep up the dream, I'm about to start very soon myself.
Marc
perth_ute
« Reply #28 on: March 12, 2015, 08:25:18 PM »
Going there tomorrow night to see the progress. The cross member is from a guy who does v6 conversions. Has power steering from a vp rack and short hq stubs. David
JOX515
« Reply #29 on: March 12, 2015, 09:09:07 PM »
G'day David,
Love the progress on the ute - will be a great car when finished.  Also like the front cross member, any chance that they are available to purchase as a kit. I am considering going down the rear mounted rack path with my RB30 powered wagon.  Haydn has sent me a lot on info re setting the rack up correctly, but I would like to go back to the original sump with the motor and your set up could be the way to go.
Cheers, Graeme
Ole
« Reply #30 on: March 12, 2015, 11:56:34 PM »
Looking good David, you must be pleased with what you found after the sandblasting. Who did you get the radiator from, it looks impressive.
Cheers Ole.
Adelaide SA
Re:
« Reply #31 on: March 14, 2015, 09:13:57 AM »
It's really coming together now. Glad your blaster did a good job.
perth_ute
« Reply #32 on: April 02, 2015, 02:21:57 PM »
There have been alot of little things that have added up to more and more hours but happy that it will be done right.
Back end is nearly finished and should be in primer next week.
Found some rust coming through on lower side panels behind both doors. It was filled with oil so had to be all cleaned out. More time and money but nearly there and should be in primer next week.
The inner tray holes have been filled and dents removed. There is still some panel damage from rust on the floor but will need skim coat. Now ready for mini tub. Not sure what the best approach is here. Should I split and weld in strip or cut out and weld in new fender? Keeping the current fuel tank at the moment otherwise I am going to be kicked out of home $$$.
Front panels are ready for paint in primer.
Old_Mt_Isa_Boy
My Ute
« Reply #33 on: April 03, 2015, 09:57:17 AM »
That's what I call progress well done.
Wayneb
DJ
« Reply #34 on: April 03, 2015, 11:21:20 AM »
Big steps in few weeks. Great progress.
0417 270 315
perth_ute
« Reply #35 on: April 07, 2015, 11:24:54 AM »
Not sure it was a good idea or not but have welded up the seam under the rear tail tights and the front panels under the indicators. Purchased BMW m3 seats in black leather so try to figure out how to fit them without cutting the floor pan too much. The side mounts from the bench line up perfect but the inside is going to be interesting. Any ideas would be great.
Next is to repair the patches on the roof from a past windscreen visor and clean up around the door jams.
perth_ute
« Reply #36 on: April 24, 2015, 11:14:54 AM »
Been reading other project posts and really take my hat off to them as it really is alot of work and $$. Have finished the roof now and along the way noticed it had a sun visor in a previous life.
Ariel hole on passenger side filled and cleaned.
Now getting into the gbox tunnel
« Reply #37 on: April 24, 2015, 12:28:52 PM »
Yeah who needs a radio anyway!!!
VAN059
Brisbane, QLD.
« Reply #38 on: April 24, 2015, 08:52:08 PM »
Good work!
Old_Mt_Isa_Boy
My Ute
« Reply #39 on: April 25, 2015, 09:12:12 AM »
Good stuff. All progress is good progress.
Wayne b
Pages: 1 [2] 3   Go Up
