July 19, 2025, 05:21:45 PM *
Author Topic: Early Holden goodies  (Read 2188 times)
jasonr70002
« on: April 13, 2011, 02:01:42 PM »
1. HR disc brake front end with pedders springs and HR stub axles fitted with LX torana discs and calipers. Has new ball joints and pivot nuts and seals. Has EH front outrigger already welded on and engine mounts ready to go to suit FE/FC, FB/EK, EJ/EH with red,blue,black six. Has HR steering arms and drag link etc as well and also HR steering box arm comes with it so it is a bolt in setup. Needs calipers rebuilt and discs machined. Also comes with new mounting rubbers and outrigger rubber and painted up black.
$550.00
2. EH bonnet in good condition ready to strip and paint. $130.00
3. EJ/EH diff with 3.36 centre and new brake cylinders to suit disc front end and also has aircraft grade stainless steel brake lines. Housing is painted 2 pack white with Holden lion sticker in centre of rear.  $200.00
4. VH40 booster for boosting drum brakes  $50.00
5. Worked 186. Fresh 60thou bore with flat tops. Has brand new crow megatork cam with brand new lifters and also jp timing gears. Cam is 224@50 with .467" lift and ranges is 2500 to 6000 rpm. Also has genuine Yella Terra stage 3 head fitted with genuine YT oversized valves and and big ports and is a higth compression one. Is also fitted with EH sump and pickup and rebuilt 350 holley and manifold bot no other accessories.
$850.00
I am looking for a Holden 308 and gearbox or Chev V8 and box so may trade  one or more items for a good one.
Items are in Kingsthorpe which is 20mins west of Toowoomba
Ph 0400043930 Cheers Jason
Golden Holdens FE-FC
jasonr70002
« Reply #1 on: April 13, 2011, 05:47:25 PM »
Engine sold
