August 23, 2025, 03:13:03 PM *
Author Topic: Call me an idiot but...  (Read 8660 times)
Paul In Ireland
« on: February 17, 2011, 11:36:43 AM »
I can't figure how to change a rear indicator bulb in my ute. Took off the panel, disconnected the wires, couldn't twist or pull the bulb holder so what to do next? Don't want to do the wrong thing and break something..... thinking that taking out the whole lens must be a waste of time?
Thanks,
P.
« Reply #1 on: February 17, 2011, 12:30:30 PM »
Maybe something to do with being Irish  Cheesy
I suggest if you have a missus, ask her to have a look. Problem solved!!! Tongue
REDMR2RED
FC Ute's d'best
« Reply #2 on: February 17, 2011, 06:24:16 PM »
If it's a standard bulb holder it should have prongs around the bulb holder that spring into position.  Use a screw driver to lever it out, it might be rusted in.
I'll dig out a pic and email it to you.
Red
1959 FC Holden Ute
surferboy
10,000 POINTS !
« Reply #3 on: February 17, 2011, 08:04:46 PM »
Take it to an auto electrician and ask him to change the bulb for you.  Grin
 Cool Cool Cool
cruisin's great with a 58
surferboy
10,000 POINTS !
« Reply #4 on: February 17, 2011, 08:06:03 PM »
Then go and work all day Sunday at penalty rates so you can pay the bill   Grin
 Cool Cool Cool
jack_fc
SouthWest Coast, Victoria
« Reply #5 on: February 17, 2011, 08:20:59 PM »
'how many polititians does it take to change a light bulb?...'
(with sincere apologies to Paul, who's not a polititian.... yet  Wink  but lots of us hope he gets there; me included!)
smithy
yeah its purple !
« Reply #6 on: February 17, 2011, 08:26:32 PM »
None they prefer us kept in the dark Grin
How long to go Paul?
Na but with the bulb holder, they do become well and truly stuck over the years. Hold it by the base and not the wires jiggle up/ down and side to side you will see it finally coming free Wink
« Reply #7 on: February 17, 2011, 08:28:02 PM »
if u dont already have a missus, id suggest u not necessarily get one just to change the bulb cos may cos a few bob more than a sparky.
on a serios note, get a rag, preferrrable a towel type, make it slightly damp and wrap it over holder, clamp your hands as tight as u can and give it an almighty yank! It may help to yell out as you pull as hard as u can (like a tennis player)......repeat again if doesnt work. it is probably just stuck. it may help to spray a crc tube around the endg to free up any rust first.
jack_fc
« Reply #8 on: February 17, 2011, 08:41:29 PM »
Hold it by the base and not the wires jiggle up/ down and side to side you will see it finally coming  Wink
hmmmm...
 Smithy, sounds a bit like someone I live with...  Wink
Paul In Ireland
« Reply #9 on: February 18, 2011, 08:33:53 AM »
OK, OK - I get the point. Yes, it was very difficult to pull out but I did get it out, Just didn't want to do the wrong thing and break it as I have no spares.
Now, with a new bulb that works, when I put it in, it stops working. Like the pressure of pushing it loosend the bulb somewhat. Temporarily, I have sat it in the slot and wedged a rag behind it so it works. Any better suggestions? What would be loose to cause it to do this?
Thanks again - and the election is Friday 25th, Will know by lunch the next day I have been knocked out of the count....
« Reply #10 on: February 18, 2011, 08:37:26 AM »
Get a scourer and clean up the mating surfaces, the earth is made through the metal as the glode holder is pushed into the housing.
REDMR2RED
FC Ute's d'best
« Reply #11 on: February 18, 2011, 08:42:10 AM »
As Stinky said it most likely is an earthing problem.  It could also be a wiring problem.  Did you test the old globe?  If that works check you have 12 volts in the globe holder.
1959 FC Holden Ute
Paul In Ireland
« Reply #12 on: February 18, 2011, 07:14:05 PM »
I think it earths ok, the problem is as the unit is squeezed into place, it sort of pops the bulb out a bit, losing contact. In my hand I can shake it about and it works.....
« Reply #13 on: February 18, 2011, 08:00:14 PM »
often i also find that if i push it in and out a lot it loosens up too.  Wink
if u have a solder iron, find the loose bit and put a small dab of solder on the mating surface. this will make a tight fit. u need a tight fit not a loose fit.
« Reply #14 on: February 18, 2011, 09:26:00 PM »
is there a spring under the globe/bulb contact?
« Reply #15 on: March 02, 2011, 07:03:54 PM »
Yep under the bakerlite bit with the contact in it theres a spring under it.
Page created in 0.039 seconds with 21 queries.
