August 23, 2025, 06:25:48 AM *
Author Topic: Engine number  (Read 3079 times)
BLOK
« on: January 01, 2011, 10:53:35 PM »
Pulled the motor out of my fe sedan and tryed to find some info on it but cant seem to match any thing up ,it has no letter in front of the number so i thought FX FJ ,this motor has 7 numbers it reads
H138
7408858
any help would be apreciated thanks
« Reply #1 on: January 01, 2011, 11:03:13 PM »
next to the distributor base there is a machined piece of casting - look there.
BLOK
« Reply #2 on: January 01, 2011, 11:40:46 PM »
thats it
Uploaded with ImageShack.us
« Reply #3 on: January 02, 2011, 12:10:08 AM »
Look a bit higher up, on the flat piece below the side plate, next to where the distributor goes into the block, the number should be there
BLOK
« Reply #4 on: January 02, 2011, 01:12:36 AM »
Thanks zulu found the plate and scrubed her down with a tooth brush and there it was  cheers
Ken's 57
« Reply #5 on: January 03, 2011, 05:19:26 PM »
BLOK - If I'm not mistaken H138 indicates that this block casting was poured on August 13th 1958. H being the 8th letter of the alphabet refers to the 8th month, while 13 is the day in August it was poured and of course 8 is short for 1958.
Cheers... Ken
Page created in 0.025 seconds with 19 queries.
