September 03, 2025, 01:18:08 PM *
Pages: 1 2 [3] 4 5 ... 9   Go Down
Author Topic: FE sedan project  (Read 114311 times)
« Reply #40 on: March 07, 2011, 08:08:16 PM »
Blok  Nice work  Grin you could have used a HR sway bar and turned it upside down and put a scallop in the outrigger and weld in a half round for reinforcement  ......FC427 ....
BLOK
« Reply #41 on: March 07, 2011, 08:33:42 PM »
Thanks FC427 its good to know different options ill store that in the memory bank
« Reply #42 on: March 07, 2011, 09:41:44 PM »
Also repositioned the engine mounts on the HR front end ,i had to raise them up so the gilmer belt drive would clear the swaybar
I had a similar problem with the metal fan not clearing the sway bar, someone pointed out that an EK swaybar has a dip in it, swapped them and it's all good.
BLOK
« Reply #43 on: March 08, 2011, 09:30:47 PM »
Got some more done yesterday but had trouble posting so here we go again
I used 6mm plate for the tunnel crossmember
This is a converted wipermotor out of an old corona it works great and the wipers line up what a fluke
BLOK
« Reply #44 on: March 08, 2011, 09:45:36 PM »
Pulled this blower heater out of a 60 series toyota landcruiser ,it comes from under the drivers seat and is a small size so i will try to fit it up as a demister
« Reply #45 on: March 08, 2011, 11:02:34 PM »
nice enginuity
BLOK
« Reply #46 on: March 09, 2011, 12:13:07 AM »
Just another view of that little heater
smithy
yeah its purple !
« Reply #47 on: March 10, 2011, 09:05:44 AM »
Hey blok, I used the very same heater great little unit. I mounted mine vertically under the dash with the two pipes coming through the firewall at about the height of the head. For hoses use heater hose from a commodore vh I think. These have a 90 deg bend and reach the water pump with ease. You may find you will need to use spacers to bring the heater body away from the inside firewall otherwise the pipes will foul on the engine.
As far as demister setup I had someone make up an aluminum box with two 50mm outlets at the front and two smaller approx 25mm at the back for demister hose..
Let me know if you need some pics and I will see what I can dig up.
Dean
BLOK
« Reply #48 on: March 10, 2011, 12:36:20 PM »
Great stuff Dean thats how I am thinking of mounting it ,thay are a good small size  and blow plenty of air .if you can find those pics that would be great
BLOK
« Reply #49 on: March 11, 2011, 06:51:37 PM »
Got the tunnel welded in ,i screwed it in first and then ran the welds
BLOK
« Reply #50 on: March 11, 2011, 06:55:45 PM »
NEW CROSSMENBER WELDED TO THE TUNNEL  OVER HEAD WELDS ARE ALWAYS FUN
BLOK
« Reply #51 on: March 11, 2011, 07:14:37 PM »
Looks like we are goimg to have another wet weekend here in sunny Coffs Harbour but still plenty i can do in the shed  Was hoping to get the engine bay painted but will have to see what tomorrow brings
Found this picture of the old girl the day i went to check it out after seeing her on evilbay
And after a wash at home
Old_Mt_Isa_Boy
My Ute
« Reply #52 on: March 11, 2011, 08:06:11 PM »
Looking good BLOK. I like the tunnel support treatment. I've got some 6mm so might try it myself.
Wayne B
smithy
yeah its purple !
« Reply #53 on: March 11, 2011, 08:11:21 PM »
Here you go blok, got some problems trying to load pics but this may give you an idea
smithy
yeah its purple !
« Reply #54 on: March 11, 2011, 08:19:36 PM »
And another one, same same but different.
BLOK
« Reply #55 on: March 11, 2011, 08:27:10 PM »
Great stuff Smithy that does help ,the shroud on the bottom looks simple enough and what did you use for the ducting is that vacuum cleaner suction hose ,Cheers mate
BLOK
« Reply #56 on: March 11, 2011, 08:35:41 PM »
Hi Wayne hows that Ute of yours going ,mate the 6mm plate is heaps strong enough and gives you plenty of clearance and easy enough to install I just cut the shape out of cardboard and my mate put it through the roller ,i used a longer piece than was needed so i could bend and manipulate the curve if needed
« Reply #57 on: March 11, 2011, 09:29:12 PM »
Nice looking car BLOK, I didn't know your car is a Standard or a Business Sedan ? either one, it's a rare model, just as it left the factory, without blinkers.
Look forward to seeing pics of the finished car
smithy
yeah its purple !
« Reply #58 on: March 11, 2011, 09:56:40 PM »
Well spotted, actually swimming pool suction hose. But I did use vacuum cleaner ends for the demister vents  Wink, to switch between demister and heat I just turn the heater vents to closed, simply redirecting the heat. Simple but works.
This is the other one I wanted to show
Dean
BLOK
« Reply #59 on: March 13, 2011, 01:39:01 PM »
Sunshine today so got a bit of painting done
And cut the rust out not that there was a lot
Pages: 1 2 [3] 4 5 ... 9   Go Up
Page created in 0.046 seconds with 16 queries.
