September 02, 2025, 11:40:45 PM *
Pages: 1 [2]   Go Down
Author Topic: FE front disc brake upgrade and more advise please ?  (Read 20749 times)
brett_f
« Reply #20 on: December 23, 2010, 05:31:13 PM »
FE 4 ME,
I am a locksmith. To remove the barrel you must have a key that turns the lock from lock to on. You then turn the lock all the way to the left (lock position) insert paper clip and depress and then turn further to the left and then pull out. To replace just insert new barrel and turn right with key.
Barrell should have code number stamped onto it if you need to get another key cut.
Regards brett
brett_f
« Reply #21 on: December 23, 2010, 06:42:32 PM »
FE 4 ME,
Forgot to mention. DO NOT GET SOLEX LOCKS. They will give you all sorts of trouble and are not secure. As they protrude from the panels, you can get muliti grips onto the outside and turn them to open the vehicle. You also have to slightly modify the hole which wont allow the holden locks to be firm anymore should you want to go back to original. You can't get a solex lock for the ignition.
Hope this helps
Brett
« Reply #22 on: December 23, 2010, 08:11:29 PM »
do what hoon said and get locks all keyed the same with whatever barrel u want using door locks or whatever, u dont want a shit load of keys its annoying. the locksmith will do it in front of you in 2 seconds and you will hate him for it lol  Tongue
Pages: 1 [2]   Go Up
Page created in 0.026 seconds with 19 queries.
