September 09, 2025, 05:42:17 PM *
Author Topic: Rear Bumpers  (Read 4195 times)
earlyholdenfan
« on: December 20, 2010, 02:28:56 PM »
Could anyone enlighten me as to the similarities and differences between rear bumpers ??
Is there a difference between FE and FC? (if so what are they?)
Is there a difference between Sedan and Wagon?? (if so what are they?)
Matt
« Reply #1 on: December 20, 2010, 02:41:18 PM »
Just the brackets and if people have added number plate surrounds ect wagon and sedan the same all around same with front on ute.
I think im right.
Im sure i will be told if i am not Cheesy
« Reply #2 on: December 20, 2010, 10:07:21 PM »
fchoon is quite correct but maybe didn't answer the whole question.
Unlike front bumpers, the rear bumpers on FE and FC are identical on all sedans and wagons. The irons for the wagon are the same as the sedan.
The ute and van rear bumpers and irons are obviously completely different to the sedans and wagons but the same between FE and FC.
« Reply #3 on: December 21, 2010, 12:05:02 AM »
Is the centre section on an FE front bumper the same as the rear centre section on an FE/FC sedan /Wagon. If so what is the difference between the front and back bumpers, are they the same? If not what is the difference between FE and FC front bumpers
« Reply #4 on: December 21, 2010, 05:33:26 AM »
Yep all the same.....
Knew i had forgot something.
Pete
earlyholdenfan
« Reply #5 on: December 21, 2010, 08:39:51 AM »
Brilliant stuff - many thanks to all!
Matt
« Reply #6 on: December 21, 2010, 10:20:21 AM »
FE Special Sedan & Wagon front bar has the number plate surround
All other FE front bars, Standard, Business Sedan, Commercials do not, but the holes are there and you often see them fitted.
FC front bars, regardless of model, do not have the number plate surround, nor do they have the holes there to fit them, however, over the years many bars & bar centres have been swapped.
« Reply #7 on: December 21, 2010, 10:50:51 AM »
Here's a quirk you may not have noticed - have a look at the FC on the cover of the sedan/wagon sales brochure. You will see that it has a FE commercial front bar on it with the holes clearly visible - not like production. Inside the brochure there is a green FC standard sedan also with the same bumper. All other pics don't show holes.
Stewy
sa-club
Jeff Stewart
« Reply #8 on: December 21, 2010, 10:56:52 AM »
In the parts catalogue the FE centre section has the same part # for the front and the rear #7408731,
 which is also the same as the FC rear. The FC front centre section is #7414456 and is most likely the same but without holes.
Cheers Stewy.
Stewy
sa-club
Jeff Stewart
« Reply #9 on: December 21, 2010, 11:06:06 AM »
And if you look in the FE sales brochure the Business sedan and the Standard sedan pictures dont show the holes either  Huh
Stewy
