August 12, 2025, 01:04:27 PM *
Pages: 1 [2]   Go Down
Author Topic: aussie desert coolers  (Read 22367 times)
njf690
heya
« Reply #20 on: May 27, 2017, 07:00:21 PM »
I think I'm going to try the vl radiator . Seems like less cutting to fit it and won't look out of place in the car . And run the biggest fans I can . Will post photos once I start the upgrade .
« Reply #21 on: May 28, 2017, 07:20:37 AM »
Did you run vl fans with that radiator . Flick some pictures if you can .
Thanks jb for the photos gives me a better idea of what I could do . Neat job
I run a pair of Davies Craig fans. I chose two smaller fans, as they give me a good air flow (2 x medium flow = 1 x big fan), allow me to spread that flow over a greater surface area of the radiator (more effective than shrouding - its one reason modern cars often run twin thermos instead of one big one), and are slim enough to tuck up under the bonnet latch mechanism without too much butchery.
njf690
heya
« Reply #22 on: May 28, 2017, 03:15:49 PM »
Cheers Harv
Anyone used the vl radiator in the fc Holden . Or any other photos of the cooling system .
njf690
heya
« Reply #23 on: May 31, 2017, 04:20:11 AM »
anyone used FENIX radiators or know of them being used for projects?
njf690
heya
« Reply #24 on: May 31, 2017, 06:53:33 PM »
Tried fenix today only to find out they don't have any commodore radiators in stock and don't know when they will get any either . Also didn't have any fans or shrouds Huh Not good
« Reply #25 on: July 14, 2017, 07:38:02 PM »
What did you end up doing?
freddyc
« Reply #26 on: July 28, 2017, 07:49:21 AM »
I used a 54mm triple row, standard FC top tank custom bottom tank with the hose inlet/outlets moved to suit a V6 in my car. Fits in original position. No overheating issues yet. Also has A/C condenser in front.
fred
Townsville North Queensland
njf690
heya
« Reply #27 on: August 16, 2017, 04:00:28 PM »
i ended up going aluminium radiator from Proflow in a universal style .  bit of cutting ,making of supports and mounts . in now with Spal puller fan. had to modify the top neck of radiator to miss the drive belt and pulley . welded a 90' pipe with a neck.
Pages: 1 [2]   Go Up
