September 27, 2024, 10:13:08 AM *
Author Topic: Tasmans for sale  (Read 3332 times)
FE_225
« on: March 01, 2003, 11:50:57 AM »
Hi
I've got 3 x 14" Tasmans in VGC that I don't need. Problem is, they are Ford stud pattern . Any body out there with Tasmans on their car want a matching set for a trailer?
$90.00
Let me know if interested.
Tony
kma
If you want it to REV get a CHEV
« Reply #1 on: March 02, 2003, 11:13:12 AM »
Tony, I know of a workshop who can change the stud pattern if you want to use them yourself.
What condition are the caps, "if any"??
FE_225
« Reply #2 on: March 02, 2003, 11:37:19 AM »
Hi kma
I've already got a set for my FE.
I was going to use them on a trailer myself but have since bought a ute, so I have no use for them. Anybody want to swap an fe/c ute or wagon for a wb ute  Grin
Sorry. no centre caps.
Tony
kma
« Reply #3 on: March 03, 2003, 09:25:48 AM »
Hi Tony,
Thanks for the reply.
Reguards, Kevin
Andrew FAIRS
« Reply #4 on: April 29, 2003, 12:40:46 AM »
Tony,
I am interested - I am after a pair of Holden pattern, but it must be possible to machine the Holdn pattern into them??
Andrew
FE_225
« Reply #5 on: April 29, 2003, 03:49:35 AM »
Hi Andrew
Kevin said they can be changed to Holden pattern. Don't think it would be too hard.
Anyway, I've still got 'em. Send me a pm or email if your still interested.
Tony
superfly
« Reply #6 on: April 30, 2003, 07:22:37 AM »
Hey guys,
One problem with changing from ford stud pattern to holden is that ford use 1/2" studs and Holden use 7/16 studs  :-/.
plus im guessing that there falcon, & there pitch circle is alot larger than early holden
HARKO
« Reply #7 on: April 30, 2003, 08:56:12 AM »
Not long ago I had a similar offer 14 inch tasmans that suited Ford ,The seller then told me that he can have them welded up and redrilled in the better stud pattern which I wouldnt trust myself because the centres are cast and the weld wont be which will alter the molecular structure thus causing a weak spot in my own opinion, $25 a wheel was quoted , Do yourself a favour and have a chat to the local machinist/Engineer
FE_225
« Reply #8 on: April 30, 2003, 10:28:04 AM »
Your spot on Harko.
I spoke to a wheel joint about welding up mags, and they said DON'T DO IT! The welding buggers up the alloy casting and they can break. They said it's safer to drive around with cracked mags than welded ones. Personally, I wouldn't have the Tasmans welded and redrilled, it would be asking for trouble.
Kevin: Can you shed any light on how the guys down your way change the stud pattern on mags???
Tony
Page created in 0.052 seconds with 20 queries.
