August 23, 2025, 10:23:02 AM *
Author Topic: Oil Light  (Read 1834 times)
fe
My FE
« on: October 23, 2010, 07:49:13 PM »
Hi
My Oil light flicks on and off then sometimes never comes on
Oil levels are fine ,any suggestions  Lips sealed
« Reply #1 on: October 23, 2010, 08:55:34 PM »
Pull out the sender and check it  Undecided, I had some gunk blocking my oil pressure sender giving me low readings, cleaned it up and it was all good.
GREGD
FE & FC HOLDENS ROAR
« Reply #2 on: October 26, 2010, 11:38:30 AM »
Hi
First, fit a manual oil pressue guage to check that the pressure is ok.
Then check your wiring as the fault can often be a short circuit remember your wiring loom is 50+ years old and will be brittle in spots the insulation may have broken away, a bare wire could short against the body causing a flashing warning light.
Good luck
GREGD
Page created in 0.032 seconds with 21 queries.
