May 21, 2025, 02:36:15 AM *
Pages: 1 ... 7 8 [9] 10 11 ... 14   Go Down
Author Topic: FE sedan  (Read 320035 times)
« Reply #160 on: October 13, 2015, 12:29:52 PM »
Im running a basic Haltech sprint computer so signal will come from ECU
weddo
HIS, HER's & OUR's
billnjudiwedd@gmail.com
« Reply #161 on: October 13, 2015, 09:32:21 PM »
Brilliant set up Pete, following with interest.
Post it on FB sites as a follow up as well.
regards
Weddo
« Reply #162 on: October 23, 2015, 09:35:56 PM »
Getting there with the old girl.
Lots of rubbing ...
« Reply #163 on: October 24, 2015, 09:09:10 AM »
Looks great Pete straight
Wayne b
« Reply #164 on: October 24, 2015, 04:58:18 PM »
All finished on the subframe.
Self taught painter very happywith the finish.
« Reply #165 on: October 24, 2015, 06:45:35 PM »
Another big weekend Pete. Nice job.
« Reply #166 on: October 24, 2015, 07:01:02 PM »
Looks good Pete, just a suggestion on the colour of the front of the subframe. The radiator side panels look better black - this highlights the chrome on the grille. Painted side panels tend to wash out the chrome. When I painted the van (light blue) I left the front in colour, but then painted it black later.
« Reply #167 on: October 24, 2015, 09:15:12 PM »
Thanks Ken
i had thought about it but there was something i liked about the blue and chrome lighter colours it looks bigger or brighter behind in my eyes..
 i remeber when wayne AKA old mt isa boy did his FC ute rally appealled to me ..
can change later on if need be..
« Reply #168 on: November 01, 2015, 08:52:12 PM »
Firewall painted
Subframe is all fitted up very happy it lined up great.
Also be warned do not use ebay wheel cylinders fronts are 6 months old and leaking the wheel cups have strange grooves and are perished .
I found a set of stainless sleeved ones in the roof just need to get new pbr wheel cups.
« Reply #169 on: November 01, 2015, 10:02:41 PM »
Onward & upward. Thanks for the tip on the wheel cylinders Pete.
« Reply #170 on: November 08, 2015, 07:04:01 PM »
Another weekend gone.
All upper lower control arms
Sway bar
Crossmember all little bits and pieces sandblastes and etch primed then sprayed in valspar satin black.
Only a few hrs today but crossmember fitted with new rubbers and new bolts torqued up correct  spacers measured and fitted correctly.
New brake lines made and fitted.
Wheel cylinders blasted repainted rebuilt.
New wheel bearings and seals fitted.
Spacer cut for the timing wheel timing wheel countersunk screws fitted ..
« Reply #171 on: November 08, 2015, 08:04:08 PM »
Great progress!
« Reply #172 on: November 08, 2015, 08:10:43 PM »
That cross member looks like straight off the show room floor.
Wayne b
« Reply #173 on: November 10, 2015, 09:49:01 PM »
Re assembling control arms the rubbers to stop the grease were shagged so instead of having to buy the kit off rares i ordered some 25mm silicon hose works great.
Also i bought a new sata spray gun with a smaller 1.4mm nozzle to try get an even better finish.
Hopefully engine in on the weekend.
Trigger wheel all fitted perfect..
« Reply #174 on: November 21, 2015, 09:35:43 PM »
Got heaps done today.
I hate painting the steering box colours so i bead blasted and used a metal clear coat came out smick.
Did the column satin black.
Re painted radiator and 500 other bits black.
Fitted gearbox
« Reply #175 on: November 21, 2015, 09:46:22 PM »
You'll have nothing left to do tomorrow. It's looking good.
2brite
Cruizin's devine in a '59
« Reply #176 on: November 22, 2015, 10:42:11 PM »
Just a curiosity question
Are all fe fc spot welded like that along the edge above where the wiper sits and below the bonnet rubber looks pretty yucky
« Reply #177 on: November 23, 2015, 06:12:41 AM »
No they are not on the FC. It seems the employee worked how to use the spot welder properly after the FE.
I looked at a cactus FE ute up the wreckers its the same as mine.
« Reply #178 on: November 25, 2015, 07:54:38 PM »
Brake lines done.
Just started fuel tank to fit in existing hole with no mods.
camxsmith
« Reply #179 on: November 26, 2015, 07:25:04 PM »
Wow ..  I like your handy work  on the brake lines nice and neat. Can not wait to see the fuel tank assembled..
Pages: 1 ... 7 8 [9] 10 11 ... 14   Go Up
Page created in 0.058 seconds with 20 queries.
