August 26, 2025, 05:10:00 PM *
Author Topic: Long trips in old cars  (Read 4316 times)
Gertie
Grey & White rooles
« on: February 07, 2003, 11:02:02 AM »
Some of our newer members have indicated a reluctance to drive their FE/FC over long distances, particularly the Gold Coast at Easter.
For those members & anyone else considering a long trip in the "Old Girl". Here are a few suggestions that will help to ensure that you get there & back with a minimum of frustration. I would welcome any other suggestions.
These checks were all we used before heading off to Perth in "Gertie" in 1968 for a 6 week holiday. The only hold up was a flat tyre caused by a faulty tube (replaced under warranty)
  • Replace top and bottom radiator hoses. Carry old ones for spares.
  • Replace fan belt. Carry old one for spare.
  • Arrange to have the cooling system pressure tested.
  • While not original, old Holdens perform better in the heat with a water recovery system installed, and if done right can be a bolt-on bolt-off proposition (if you want to remove it before showing the car).
  • Replace distributor points and adjust timing. Carry old ones for spare.
  • Grease and oil change. This includes checking steering box, gear box and differential oil levels.
  • Check tyres and pressures, including the spare. 32-34 psi will provide a reasonable ride, low pressures will cause tyre wear and instability on corners. Also check for uneven tyre wear and rectify the problem with a wheel alignment and balance.
  • Check and repair any major oil leaks.
  • Thoroughly clean the windscreen inside and out.
  • Check headlight adjustment and consider the benefits of quartz halogen lights for night driving. The original lights were okay 40 years ago but the reflectors (like everything else) will dim with age.
  • Check drivers seat for weak springs, they can be very uncomfortable over long periods.
  • Carry a 4 litre container of water in the boot. If you do get stuck you may get thirsty or you may need it for the radiator.
« Reply #1 on: February 07, 2003, 11:46:35 AM »
Thanks for the tips Gertie. We can always count on you. Lol.
Al
I love FC Ute's!
« Reply #2 on: February 14, 2003, 12:28:02 PM »
Good advice Gertie,
Now is the time to get your FE, FC ready for the trip. This way gives you plenty of time to do it right. Here are more tips,
    1. have radiator flushed out, engine block back flushed with compressed air and water. Have water pump checked.
    2. change the condencer as well as the points, because if faulty can cause a lot of problems.
     3. have the front wheel bearings repacked with grease or replaced, at same time have front end checked.
      4. have brakes checked.
      5. as well as water carry engine oil and brake fliud.
   Cheers Al
« Last Edit: February 14, 2003, 12:30:32 PM by Al » Logged
See ya
Al
« Reply #3 on: February 21, 2003, 12:22:23 PM »
i always carry tools and jumper leads and tow rope.
this has helped me and others lots of times.
if running original generator always carry spares as no one in country towns are likely to have parts
Page created in 0.024 seconds with 19 queries.
