August 24, 2025, 01:21:28 PM *
Author Topic: FC diff centre  (Read 1904 times)
clements@upnaway.com
« on: June 28, 2000, 12:00:00 PM »
i have been told that the later red motor type diff centres will bolt into an fc housing allowing you to change ratios. is this so
Tony Galea
« Reply #1 on: June 28, 2000, 12:00:00 PM »
Yes you are correct just change your rear uni to a red moter type and of you go easy as that
mboyle@one.net.au
« Reply #2 on: June 30, 2000, 12:00:00 PM »
Yes you  can change the centre into the FC housing but the FC tailshaft will not connect up to the later centre, they have different uni joints.
Page created in 0.02 seconds with 17 queries.
