September 09, 2025, 05:44:37 PM *
Author Topic: mounting hr crossmember  (Read 4611 times)
gwuthie
« on: January 25, 2010, 12:17:19 AM »
I assume this is simple... but. When mounting the hr xmember to FC frame, which rubbers should I use as the tit bit where the bolts come thru are different.
« Reply #1 on: January 25, 2010, 07:55:57 AM »
Rares makes the rubber mounting kit for mounting the HR crossmember to FC it has the correct rubbers needed.......FC427........
FB_MAD
« Reply #2 on: January 25, 2010, 09:58:32 AM »
You need Rare Spares kit
"Front End kit, front end mounting rubber FE-EK with HR Xmember"
Part number FEK4A
Has anybody seen my red pen??
« Reply #3 on: January 25, 2010, 11:22:17 AM »
Do they do this kit in Noelathane??
« Reply #4 on: January 25, 2010, 11:43:34 AM »
They make the outrigger bush don't know about the rest  Huh Huh ...FC427.....
Rusty_T
« Reply #5 on: January 25, 2010, 11:58:54 AM »
Hi all,
What bits are in the kit?
Rusty
« Reply #6 on: January 25, 2010, 04:11:57 PM »
In the past I've used the following mix of parts;
HR bolts, nuts, spring washers and the 4 longer FC spacers.
The HR doughnut which goes between the subframe and the crossmember.
The FC upper rubber and metal retainer.
But the kit makes it all a lot easier.
fc2360
« Reply #7 on: January 25, 2010, 10:53:46 PM »
fulrom suspensions in their super pro bushes (urathane material) do a fc to hr front end conversion kit . reguards fc2360
hrpremier
Jason
Jason Fewins
« Reply #8 on: January 25, 2010, 11:01:42 PM »
Put this kit into my HR Front end about 4 weeks ago.  As for as rubber kits go very happy.  A picture of the contents of the kit can be found under the FC folder in my shed at the attached link..............  4 upper cross member bushes, 4 lower cross member bushes and a Outrigger  Rubber to go in the mount below the radiator.  $50 odd dollars from memory.
Bought the kit through Auto1 (Rare Spares Outlet)
ratbox
« Reply #9 on: January 26, 2010, 09:02:43 AM »
don't buy the kit from spectrum rubber st marys ex peter jacksons, $50 odd from rares well over $100 from spectrum Huh
kit contains 4 upper rubbers 4 lower rubbers and outrigger rubber
Page created in 0.043 seconds with 20 queries.
