August 17, 2025, 06:46:31 PM *
Author Topic: hoodlinig listing wires  (Read 4570 times)
NO NAME
« on: January 09, 2010, 10:36:10 AM »
i pulled out my windscreen, scratched the cowl vent doing it, now ready to start finally fitting my hoodliner but i noticed i am missing a wire, its the 3rd from the front in a wagon.
 all the other wires are thick except 1 wich is thin.
 is the 3rd wire from the back thick or thin?
 i have thick wire here but if its a thin wire where do i buy thin wire on a saturday?
 is there another wire in a wagon rooflinig i could copy to make the 3rd one back?
« Reply #1 on: January 09, 2010, 10:49:14 AM »
In the sedans the listing sleeve that goes in where the interior light is has two pieces of thin wire, one either side, that hook into a set of barbs/clips on the support rib. Otherwise all the support bows are all the same guage.
NO NAME
« Reply #2 on: January 09, 2010, 10:55:50 AM »
shit, now i recall that there was one wire in two seperate peices, how would i go about making that?
NO NAME
« Reply #3 on: January 09, 2010, 12:05:22 PM »
after a big search ive found one of the short wires, does anyone know where i might buy wire for the other piece, is it mild steel, spring steel or anything? all i can think of is bunnings
« Reply #4 on: January 09, 2010, 12:47:16 PM »
It's only mild steel. I think you could probably use a coathanger straightened out.
NO NAME
« Reply #5 on: January 09, 2010, 12:54:03 PM »
thanks, i was just looking at it thinking coat hanger, i will go and check the wardrobe.
freddyc
« Reply #6 on: January 09, 2010, 01:35:13 PM »
I have one I could post you if needed. A coat hanger that is
Townsville North Queensland
NO NAME
« Reply #7 on: January 09, 2010, 03:22:50 PM »
thanks for the offer but i just got some after 3 hrs of searching shops,  they are plastic coated but i can pick it of if need be.
now i have to clip it up and work out how to trim the edges of the headliner to shape
« Reply #8 on: January 09, 2010, 04:05:07 PM »
No Name, if you can wait till Monday try taking your sample wire here, you should be able to get it already straightened, I think Huntingwood is another name for Eastern Creek ?
Whites Wires
4 Decker Place
Huntingwood
NSW 2148
nsw@whiteswires.com.au
Ph (02) 8602 0000
Fax (02) 8814 9029
v8 wagon
« Reply #9 on: January 09, 2010, 10:49:42 PM »
Try youre local fencing contractor( chainwire), we buy it from whites wires.
steve
Page created in 0.024 seconds with 22 queries.
