July 04, 2024, 11:18:47 PM *
Author Topic: indicator leaver  (Read 4312 times)
BLOK
« on: December 31, 2009, 05:55:00 PM »
hi guys i have an fe ute that has indicators on it but no leaver on the column i thought it mite be broken and pulled the steering wheel and horn mechanism of but no sign of a leaver or any wiring ,any ideas cheers Blok
« Reply #1 on: December 31, 2009, 06:41:22 PM »
BLOK, Commercial models did not come with blinkers, they were an optional extra, FE utes had no blinker lights on the front as well, but FC did as they had a dual function & operate as parking lights
With FE some owners fitted up the correct GMH package while others fitted up aftermarket blinkers, these were usually operated via a column mounted lever or in some cases a switch on the dash
I have an FC panelvan that has no blinkers that was registered up until the 70's, not sure about the requirements now in the different states or where you are but if you want originality, leave it as is. It's seldom you see them still un fitted.
BLOK
« Reply #2 on: December 31, 2009, 09:30:06 PM »
thanks zulu I just went out in the dark and the front are operating as parker lights and go out when the headlights come on ,my Ute is rough and sitting in a paddock for years didn't do it any good I have only just picked it up from out at mungindi and the geckos are still crawling around in it ,i was very surprised when i threw a coil and battery in it and ran fuel straight to the carby that it started on the second try and most of the lights worked its got a 161 in it
BLOK
« Reply #3 on: December 31, 2009, 09:52:37 PM »
big job inner and outer sills are gone , floor what floor but for a hundred bucks i cant complain and ill be doing most of the work myself
Have never seen a front bumper with 4 thingymijigs on it before is that an add on or standard
« Reply #4 on: December 31, 2009, 10:09:12 PM »
Ahhhhh, yes -------  Somebody has got creative with the over riders.
Must be the FE Kingswood front bar Tongue
Ken Grin
Johns
Model: something else...
« Reply #5 on: January 01, 2010, 10:50:10 PM »
No Ken, its the Irish one. To be sure, to be sure. (sorry Paul Grin)
For all that it looks pretty good Blok, good luck with it.
« Reply #6 on: January 02, 2010, 12:47:40 AM »
Agreed: shame about the sills and floor, because the patina on the rest of it is magnificent.
Good luck with it.
Paul In Ireland
« Reply #7 on: January 02, 2010, 01:49:57 AM »
Its OK John - wouldn't mind it actually, cool look and different!!
BLOK
« Reply #8 on: January 02, 2010, 09:00:44 PM »
found this in the glovebox today ,looks fairly old
Page created in 0.037 seconds with 21 queries.
