June 18, 2025, 08:44:10 PM *
Author Topic: speedo question  (Read 4068 times)
Sheriff
FEs rule!
« on: November 12, 2009, 06:40:22 PM »
My speedo has been playing up lately.   Goes a bit haywire, fluctuating wildly and makes a grinding noise off and on.   Before I pull anything apart, is it more likely to be the cable, or the speedo internals.   Thanks, Mike.
CraigA
« Reply #1 on: November 12, 2009, 07:15:48 PM »
As a first step lubricate the inner cable. Typically the things bind from being dry.
To do it properly you need to remove the speedo cable, disassemble & clean the inner and the outer cable sheath, then lubricate with some light oil and refit to the car.
« Reply #2 on: November 12, 2009, 07:17:24 PM »
More likely the speedo - the grease dries out and they eventually seize. I have seen many people who break a speedo cable, put a new one in and then snap it straight away & then realise it was the speedo all along.
The speedo needs to be pulled apart and lubricated.
A good test is to spin the speedo by hand - you should be able to get at least 20 mph out of it.
« Reply #3 on: November 12, 2009, 07:29:09 PM »
I had the exact same symptoms in my wagon driving back from Castlemaine, by the time I got to Adelaide the speedo wasn't working, when I pulled it out there was a mess of metal filings inside  Cry
snuff69
« Reply #4 on: November 15, 2009, 09:53:09 PM »
hey Ken just about to reinstall my speedo . what should I lube it with and which bits. I have a new cable to go in  Thanks Dave
« Reply #5 on: November 16, 2009, 09:12:07 PM »
Open the speedo case up and lubricate all the geared sections, work oil into all the shaft areas - especially the main shaft area where the cable goes in.
KFH
« Reply #6 on: November 16, 2009, 10:29:38 PM »
Ken  Would the the oil be sewing machine specification or a heavy grade oil?
« Reply #7 on: November 17, 2009, 07:08:36 PM »
Sewing machine grade is OK because it will penetrate easier. Should last for quite a long time after that.
snuff69
« Reply #8 on: November 17, 2009, 07:41:39 PM »
thanks Ken   Dave
KFH
« Reply #9 on: November 17, 2009, 09:51:49 PM »
Thanks Ken.     Keith
Page created in 0.038 seconds with 22 queries.
