May 26, 2025, 02:47:21 PM *
Author Topic: Fitting block hugging headers to SB Chev in FC  (Read 3470 times)
Stubzy.69
« on: October 10, 2009, 10:14:49 PM »
Has anyone fitted theese before? if so could you give me brand ect.
Cheers Stubzy.69
ratbox
« Reply #1 on: October 12, 2009, 07:20:37 PM »
pretty sure you can't use them on an FC
tuffute
« Reply #2 on: October 12, 2009, 09:19:53 PM »
You would be able to make your own extractors to hug the block as a small block Chev is narrower than the holden v8 engine,
of course what rack & front end you are using will determine how they need to be routed
fcv85l
« Reply #3 on: October 20, 2009, 08:58:44 PM »
you can fab your own set and notch the subframe,or cut holes
« Reply #4 on: October 20, 2009, 10:05:34 PM »
If you want to get a little more room to get the exhausts down the sides  get rid of the side engine mounts and make up a front plate to mount the engine, Your primary pipes will only be around 1 1/2" but that should be OK for around 350 HP ......FC427.......
« Reply #5 on: October 21, 2009, 11:02:52 AM »
fun and games!
« Reply #6 on: October 21, 2009, 03:54:55 PM »
These might go close or only need minimal modification you can just see the front plate  .....FC427....[img[img[/img][/img]
Page created in 0.052 seconds with 20 queries.
