May 28, 2025, 03:57:07 AM *
Author Topic: Rubbers  (Read 3004 times)
« on: September 21, 2009, 11:38:12 AM »
Just wondering if anyone out there has actually or thought to fit door rubbers from a modern car?
I am guessing there would be a few mods needed, but I am sure NVH would improve dramatically if done properly.
« Reply #1 on: September 21, 2009, 12:22:42 PM »
I've seen a few cars fitted with modern-style rubber-backed bailey channel (rather than the original stiff metal and felt style). Definitely an easier and often a neater job, but doubt it has much impact on NVH. As far as the rubbers around the door are concerned, the modern hollow style rubber would probably have a better seal (being much wider but compressing better), but it would be a big job to try and get right.
Given the shape of the car and its (lack of) wind resistance, and the pretty ancient A-arm front and cart-spring rear suspension, I reckon that ROI would be pretty low.
But that's just my opinion.
CraigA
« Reply #2 on: September 21, 2009, 12:42:14 PM »
Rubbers are only part of the issue. Like RET correctly says your are pushing what amounts to a brick through the air so you won't get it 100%
That said, my FC uses multiple sound deadening layers and is actually very smooth and quiet.
Under the car uses spray on sound deadener, as does the internal floor and inside the door panels.
On the inner floor I then use a sound proofing sheet, the same type used to insulate the cabins in earth moving equipment (from Daley's).Then I use the traditional cotton wadding underfelt and then carpet. All layers extend up to and slightly beyond the factory inner firewall insulation, and under/behind the back seat.
I've removed it now but was also using an under-bonnet sound insulation pad.
All rubbers and bailey channels were replaced with Rares parts, as was the exhaust hanger rubber.
Radial tyres also help with overall NVH.
The only noise remaining is generated around the 1/4 vent windows and sunvisor, and only above 55mph. Below that speed its as quiet as my new Mazda. Pump the front tyres up to 40psi and its also got pretend power steering  Grin
So in my opinion it can be improved over factory but you need an overall strategy.
« Reply #3 on: September 21, 2009, 12:46:01 PM »
Do the gutters factor much in the wind noise?
Johns
Model: something else...
« Reply #4 on: September 21, 2009, 01:06:41 PM »
Probably a bit hard to tell with that air brake Craig has over the windscreen Grin
CraigA
« Reply #5 on: September 21, 2009, 04:18:44 PM »
Thanks John  Tongue
The water deflectors at the quarter windows make the most wind noise, along with the 'air brake'.
In my XU1 I use the spray on sound deadener on the top and underside of the floor, two layers of cotton wadding underfelt, and then the carpet. Its also surprisingly quiet for what it is, -until 100mph when the tops of the doors start to deflect outwards. This is a known LC Torana problem.  Undecided
Page created in 0.04 seconds with 21 queries.
