May 28, 2025, 03:54:58 AM *
Author Topic: Brake question  (Read 1746 times)
jasonr70002
« on: September 17, 2009, 10:08:14 AM »
Hey fellas this might be a bit left field but can you fit/adapt the 4 piston volvo brakes and calipers to fit HR disc front end?
Golden Holdens FE-FC
« Reply #1 on: September 17, 2009, 11:38:11 AM »
Anything is possible with enough time and money  Grin I think some Torrie boys were messing around with the idea on the gmh-torana forum, not sure if it got off the ground though, might be worth a hunt.
« Reply #2 on: September 17, 2009, 06:21:30 PM »
Having designed lots of brake kits, of course it's possible. The problems you face are having to make up a set of custom hubs and a special bracket to suit the caliper mounting bolts.
In essence a brake kit needs the offset adjusted to suit the rotor and the caliper positioned so it will clear the steering and suspension components.
Page created in 0.034 seconds with 21 queries.
