June 03, 2025, 03:52:38 PM *
Author Topic: HR Front end  (Read 2888 times)
canary
« on: August 20, 2009, 08:41:46 PM »
Want to known if i use FE bolts or HR ones to fit front end to sub frame also do I tighten to fe or hr spec
THANKS in advance
Brian
« Reply #1 on: August 23, 2009, 04:48:05 PM »
You have to use sort of a half / half mixture unless you modify the front end to make it like an FC front end. This is my suggestion:
FC has a 3 layer rubber bush whereas HR only has 2.  So you need to use the FC upper long spacers (correct ones for front and rear) and the FC upper rubber bush and middle bush and then the lower FC bush, short spacer and square washer is deleted. You should tighten the bolts as per HR spec.
mph
« Reply #2 on: February 13, 2020, 10:42:11 PM »
Old thread but just what I'm looking for thanks
Sent from my SM-G970F using Tapatalk
FB special
