September 03, 2025, 01:01:07 PM *
Author Topic: acid dipping in dandenong  (Read 19002 times)
ashfe
« on: June 09, 2009, 09:42:52 PM »
does any one know the location of the car dipping company in dandenong or one in vic
Jonno
« Reply #1 on: June 09, 2009, 10:42:37 PM »
I have used Colorex in Huntingdale for doors, bonnets, subframe...not too far from Dandenong.
Cottles Bridge, VIC
Rabbitoh
FE - 'King of Cars'
« Reply #2 on: June 10, 2009, 09:16:47 AM »
26-28 Lanyon Street, Dandenong, Victoria 3175
(METALSTRIP)
phone: (03) 9792 3300
Bunnies' 22nd in 2026?
ashfe
« Reply #3 on: June 11, 2009, 07:07:17 PM »
colerex dont do acid dipping and metalstrip only acid dip panels does any one now of any where in victoria who dip shells
« Reply #4 on: June 11, 2009, 07:13:15 PM »
Rusty's Metal strip Warrnmbool 55613572 or 0407861260 and it's not ACID they use .........FC427.......
Jonno
« Reply #5 on: June 12, 2009, 07:40:03 AM »
there is a similar discussion here, including a link to a mob in dandenong:
http://www.dsk.com.au/forum/viewtopic.php?p=54956&sid=1d59f61394196af0296d8d02e856b7e8
but....I would tend to agree that it would be safer to bead blast the shell and acid dip the panels..
Jonno
Cottles Bridge, VIC
« Reply #6 on: June 12, 2009, 10:08:32 AM »
I have NEVER heard of a company that actually acid dips cars, there is a company in Adelaide that dips cars but they use an alkaline solution, the solution they use does not harm or heat the metal, removes all rust and then treats it so the rust doesn't start again. Their rep is that good that someone avtually sent their car from Mt Gambier to Adelaide to get done, bypassing a local soda-blaster.
Like shot-peening parts for a motor rebuild, blasting can harden the metal surface making repairs more difficult.
Jonno
« Reply #7 on: June 12, 2009, 02:19:56 PM »
yes...I think that, despite the common name, its usually sodium hydroxide that is used. That said some dippers do use phosphoric acid or even hydrochloric (although anything pulled out of the latter will rust very quickly unless neutralised). I guess the risk is that the solution will be very hard to remove from box sections etc.. I have certainly found it hard to remove even from hidden parts of bonnets so would not like to do a full body shell this way. Bead or soda blasting is pretty good....it does take months to get rid of the stuff afterwards...but at least its not eating away at your car in the mean time.
Cottles Bridge, VIC
« Reply #8 on: June 15, 2009, 12:58:26 PM »
Could you remove soda blast media by hosing it out thereby dissolving it?
or is this problematic?
« Reply #9 on: June 15, 2009, 02:10:59 PM »
Ed,
This was part of the idea to use bi carb as a blast media, all those that I know that use the soda as a blast media in engine rebuilding praise it so highly as when they have finished blasting it is just a matter of throw the item in the hot tub for a few minutes and hey presto all traces of blast media have been dissoved.
I cannot see why it would not be the same with a body shell, blast it, hose it down, dry it off, a quick hit with deoxidine, etch primer and then prime it to ensure that it doesn't rust.
Page created in 0.045 seconds with 21 queries.
