May 11, 2025, 06:51:08 PM *
Author Topic: Engineer requirements for NSW rego  (Read 3102 times)
tmudie
Back on the road again
« on: January 06, 2003, 08:01:11 AM »
Hi All,
are the NSW rego requirements documented anywhere, or on a website? has anyone gone through an engineer report recently? I just want to know the basics for a 179 trimatic conversion.
I understand the following:
need HR front end
disc brakes (front) rear drum ok?
additional (hadfield type) chassis
do I need a collapsible steering setup?
any other gotchas I should be aware of? Thanks
Tony
gree
chopped greens
« Reply #1 on: January 06, 2003, 08:39:34 AM »
you have to have a heater with demister, and 2 speed wipers. i don't think it is necessary to have a chassis kit for an upgrade to a 179 though, unless things have changed. drums for the rear are ok, just make sure that the slave cylinders are the correct ones for a disc brake front end so that the pressure is balanced.
not much info, but hope it helps a little
simon
« Reply #2 on: January 07, 2003, 12:24:23 AM »
All the information is available on the RTA's website - as long as you can find it Roll Eyes  They seem to move everything around every so often just for the heck of it.
Anyway, the document is called "Vehicle Standards Information #6: Guidelines for Light Vehicle Modifications".
If you type in 'light vehicle modifications' into the search bar on the RTA's website, it comes up top of the list.  I could give you the  URL, but it might move again before you read this post Tongue
Otherwise I've got a copy I can email you if you have trouble getting it from the RTA.
FWIW Single-speed wipers are OK, as long as they do 45 sweeps/minute or better.  As Simon says Grin, chassis is not required for a red motor, as long as you can hang your gearbox without one.
If you need details of a good engineer in Sydney, there's one in Mortdale that a number of club members have been to.  Do a search on the site for "Lohning" and you'll find the details where they've been discussed before.
tmudie
« Reply #3 on: January 07, 2003, 12:51:16 AM »
Thanks Simon/RET,
I've got a 2 speed wiper motor so will put that, same with the chassis I think I have the 3/4 components that I can source. I thought there was additional chassis for the frontend, but it doesnt sound like I need it anyway.
RET have found the RTA data and just printed out. Thanks
Tony
Page created in 0.037 seconds with 20 queries.
