August 29, 2025, 04:16:01 PM *
Pages: 1 ... 43 44 [45] 46 47 ... 60   Go Down
Author Topic: 365 weeks...  (Read 903104 times)
« Reply #880 on: March 15, 2014, 09:53:10 AM »
I always found that the best piece of glass and the best frame were on to different quarter windows. This sounds bad when I think about it now, but i just broke the glass in the good frame and cut the frame up on the good glass!!!!!!!
If you are using new glass then there is no problem, just smash the old glass and nothing will get bent.
The replacement rivets are hollow which is not like the originals, solid rivets need a lot of pressure to deform and were done in a press.
The easiest way to deform the replacement rivet is with a ball bearing and a good quality G clamp.  (and a helper)
The pressure can be increased gently and nothing should get damaged.
« Reply #881 on: March 15, 2014, 08:46:46 PM »
Thanks Ken, is there somewhere that we can get replacement glass? Or is it just a matter of getting some cut?
« Reply #882 on: March 16, 2014, 07:27:41 AM »
Contact mark fc427 he was getting some cut for people i think ?
« Reply #883 on: March 16, 2014, 06:38:03 PM »
This is how i did mine JB, the rivets for the pivots i got off e-bay and thanks to a mate down the hardware we discovered bifurcated rivets fit just fine if you cut the split pin part off them and hammer them flat using  a punch, as for the glass and the frame i filled it full of black silastic clamped it together and then cleaned up with turps, they came up great.
   Pedro
« Reply #884 on: March 16, 2014, 07:49:29 PM »
That clamp setup is really good Pedro - great idea
« Reply #885 on: March 16, 2014, 08:11:06 PM »
« Reply #886 on: March 16, 2014, 09:09:10 PM »
That is a great set up Pedro!! Hopefully when I get back home next month I will be able to get them out and see if they are good enough to fix. These tips will be invaluable.
« Reply #887 on: March 16, 2014, 09:11:13 PM »
Looks awesome JB,can hardly wait to see it finished.Cheers,Jamie.
« Reply #888 on: March 17, 2014, 09:28:54 AM »
Ralph Moore should have templates, he did a complete set of flat glass (excluding rear wagon section) for my wagon.
FCV08
FE FC Club of QLD
« Reply #889 on: March 17, 2014, 02:07:39 PM »
Classic Glass on the Gold Coast
http://www.glass4classics.com.au/
Craig D
« Reply #890 on: March 17, 2014, 02:41:16 PM »
Just looked at the website, glass all round for just under $1200. Then freight.
Didn't know you could get the rear screens new!
Thanks guys
« Reply #891 on: April 03, 2014, 09:40:34 AM »
Finally saw it yesterday, looks nice and clean. Sides are straight, tubs came up nice, but the whole lot has to be gapped yet after rubbers etc eventually get done.
I get 1 single day to play on it on Monday so am going to move the diff back by 25mm. Should sit the wheels back into the wheel well nicer and then can get the tailshaft done. Will have a look at the quarter vent windows and take them back to NZ to play with.
« Reply #892 on: April 07, 2014, 11:20:57 PM »
First day in about 6 months I have had a chance to do some work on the ute.
Needed to move the diff rearwards...
Not much change after a days work, but happy with the results.
FCV08
FE FC Club of QLD
« Reply #893 on: April 07, 2014, 11:48:03 PM »
That looks better Wink Wink Grin
Craig D
« Reply #894 on: April 10, 2014, 06:59:21 PM »
Pedro, do you still have the sellers name for the rivets you got off eBay? Couldn't see any when I looked through the other night.
« Last Edit: April 10, 2014, 10:31:26 PM by JB » Logged
fink
« Reply #895 on: April 11, 2014, 06:11:22 AM »
All the ups and downs Jase,in the looooong run was definately worth it!
Gaz! Cool
« Reply #896 on: April 11, 2014, 06:21:15 PM »
Definitely looks better, I ended up with two sets of the quarter window pivot rivets by mistake as i bought some and then discovered i got a set with my rubber kit, pm me your address and i'll send you a set down, the bifurcated rivets for the rest of the assembly you can get from most hardware stores, they worked well on mine and even have a shiny rounded head like the originals.
   Pedro
« Reply #897 on: May 19, 2014, 07:42:14 PM »
This might help get things moving a little.
Bleed the clutch and brakes... Bit more wiring and it may go down the street soon. But Dino is going to wait until I am there first... Maybe
« Last Edit: May 19, 2014, 07:55:11 PM by JB » Logged
« Reply #898 on: May 24, 2014, 01:53:42 PM »
Brake and clutch issues...
So I get a message from my brother today saying that he can't get pressure to the rear calipers and the clutch also won't bleed properly.
The master cylinders have been on and off the car getting trial fitted etc and then off again over the last 5 years, so wondering if the seal could have dried out... Not really sure. When we did the van they came up straight away.
Any thoughts from the brake guys out there?
« Reply #899 on: May 24, 2014, 06:21:20 PM »
Try using a vac bleed or a air one that fills from the brake up.
Make sure nipples are clear I guess
Pages: 1 ... 43 44 [45] 46 47 ... 60   Go Up
Page created in 0.044 seconds with 20 queries.
