August 24, 2025, 05:59:59 PM *
Author Topic: Lock Plates?  (Read 3899 times)
mc54
« on: April 18, 2009, 10:30:16 AM »
Just installing the flywheel and according to the manual I should use new lock plates.
What lock plates. There were none when I took the flywheel off.
Am I missing something?
Also since there were no lock washers or anything, what keeps the flywheel bolts from loosening off?
Mike
Rod
« Reply #1 on: April 18, 2009, 10:41:54 AM »
There are two plates. Each one goes across two holes. Once the bolts are installed they have a tab that you fold up to stop the bolt rotating- hence their name.
If yours didn't have them I am unsure if returning them and torquing them up will stop them coming loose.I a sure others will have some thoughts on this. Personally I would hate to put the fly wheel back on for it to come loose down the track. I would suggest locating some plates.
Rod
« Reply #2 on: April 18, 2009, 03:16:09 PM »
FC was the last model to use lock plates. After that the bolts were simply tightened to 30-35 ft-lbs and that's it. There is no lock washer. This is the same right through red motor as well.
mc54
« Reply #3 on: April 18, 2009, 04:04:31 PM »
I guess because I have an FB motor in mine that would explain no lock plates
Mike
« Reply #4 on: May 01, 2009, 03:53:19 PM »
I have always used lock plates (and Loctite too for that matter) since racing the grey motor cars. I found that the flywheels would sometimes come loose during a race meeting. On one particular engine we redrillled the crank flange and fitted helicoils and larger bolts in an effort to stop the flywheel from coming loose. This cured the problem.
The engines regularly were revved to 6,000rpm which may have been a contributing factor.
F4+ Wink
mc54
« Reply #5 on: May 01, 2009, 06:45:00 PM »
Too late. Transmission went in last week. Used threadlock so should be OK.
Just out of curiosity, if the pressure plate bolts loosen off I guess the clutch will slip, if the flywheel bolts come off, well, I can pretty much figure what will happen, but if the flywheel bolts only become loose, what are the symptoms? Bad vibration, shudder on take off?
Mike
« Reply #6 on: May 01, 2009, 07:33:15 PM »
If the flywheel comes loose there wil be an engine knock at the back of the motor. Once you hear it once then it becomes unmistakable
F4+ Wink
mc54
« Reply #7 on: May 02, 2009, 10:11:23 AM »
Lets just hope thats one noise I never hear.
Mike
Page created in 0.023 seconds with 19 queries.
