August 24, 2025, 11:39:00 AM *
Author Topic: Deleting Heater Hoses  (Read 2511 times)
Ol_Girl_58
getting there...
« on: April 11, 2009, 07:50:20 PM »
Hi all,
This is probably a very simple question, yet still one that I would like to know the answer to. I'm soon going to take charge of a new engine (or motor, whatever floats your boat), but I would like to delete the heater hoses. I have a big ugly heater in the car (out of a Nissan Skyline) that doesn't look great or even work, for that matter. So, I want to get rid of it. But what do I do with the heater inlet bit on the engine block?
Ol_Girl_58
Online Online
« Reply #1 on: April 11, 2009, 07:59:42 PM »
Got a picture of it? That would certainly help as it could be any number of heater setups.
« Reply #2 on: April 11, 2009, 08:10:04 PM »
If you are fitting a red engine then there is a thread that screws into the head, simply remove the existing tap and screw a blank plug into the head. Where the heater comes off the water pump there used to be blanking caps from GMH to suit. Try your Holden dealer to see if these are still available. Alternatively a bolt into a piece of heater hose will do the trick. Another alternative is to replace the water pump and fit one that does not have the hole drilled for the heater hose.
HTH
Ol_Girl_58
getting there...
« Reply #3 on: April 11, 2009, 08:27:22 PM »
Thanks for the reply Keith.
Stinky, I don't have any great shots, and these probably won't help.
These are photos of the engine in its' previous home - an LJ GTR Torana - soon to be installed into the FC (Webers are coming too).
Ol_Girl_58
Paul In Ireland
« Reply #4 on: April 11, 2009, 08:57:38 PM »
Well, if you can't work it out, give that new motor (engine) to me and I'll fit it with the broken heater  Grin
You can have a decent grey in a fair swap!
Ol_Girl_58
getting there...
« Reply #5 on: April 11, 2009, 09:26:59 PM »
Hi Paul,
I'm pretty sure the new engine (motor) isn't set up to run on leprechauns, Guinness or four-leaf clovers. I guess it'll just have to stay with me.  Undecided Undecided  Kiss
Ol_Girl_58
Spinner
« Reply #6 on: April 12, 2009, 09:55:14 PM »
Not quite related...
On a 253 in a HT, many years ago, i used a rubber blanking off cap that you could buy, with a five cent coin under it.  The coin is about teh same size as the OD of the outlet and helped prevent blowing the rubber cover apart.
Page created in 0.029 seconds with 21 queries.
