September 09, 2025, 12:36:46 AM *
Author Topic: Modifing hr front end  (Read 3274 times)
FATBOY
« on: January 30, 2009, 07:15:54 PM »
Has any one moved the the top pivot point(wishbone) down to help make the front ends handle better
regards fatboy
fatboy
0414712441
NosFEratu
F4+ =^^=
« Reply #1 on: January 30, 2009, 08:38:47 PM »
Yes.
I have done this on the HR front end that is going into the our FE van and also on the HT front end in our Vette.  It is a lot easier on the HT as all I had to do was drill holes 25mm lower on the shock tower.  On the HR I cut the whole tower off and and trimmed 25mm off the bottom and welded the tower back on.
I used a camber/caster gauge to locate the tower before I tacked in place.  This way I have 0 degree camber and 3 degrees postive caster with only a couple of shims.  The down side is you need shorter shocks but HQs are shorter and you may need to trim the y frame a couple mm as the top wishbone is now located where the YFrame is spotted together.  If I remember properly I have now got a better:
  • roll centre location
  • postive caster
  • negative camber curve and
  • increased tyre to mudgaurd clearance
Hope this helps.
regards
Nosferatu's darker side (John)
NosFEratu
FATBOY
« Reply #2 on: January 30, 2009, 09:07:49 PM »
Thats excellent just need to no if you took any pics of before and after .Are you running a front or rear mounted rack
regards fatboy
fatboy
0414712441
NosFEratu
F4+ =^^=
« Reply #3 on: January 31, 2009, 09:14:24 AM »
Er duh - before pics (if I'd taken any) would look like a standard front end! Roll Eyes Grin
The car is currently being mocked up with a V6 chev and as soon as it gets blown apart for painting components I'll post some pics for you.
It's running a rear mounted rack with LC LJ Torana steering arms.  To clear the chev starter motor I've pushed the motor back through the firewall a couple of inches - except for putting chassis rails in, this means a small block chev would actually bolt straight in.
NosFEratu
