July 27, 2025, 03:50:47 PM *
Author Topic: Qld Engineers  (Read 4196 times)
59fcwagon
« on: January 08, 2009, 01:30:49 PM »
Hey guys just wondering if anyone knows of a good engineer (knows fc's, lenient, etc) in the brisbane area to approve 202,  supra 5 speed and vn diff/4 wheel discs. Contact details would be great, cheers
cruiser056
cruisin to the rock and roll
« Reply #1 on: January 08, 2009, 05:37:20 PM »
Hi, I know of an engineer who can do this.  He did my car, which was virtually the same.  I will send a pm with his contact details as these days he does not advertise, just happy to have his contact pass on by word of mouth.
Michael
59fcwagon
« Reply #2 on: January 09, 2009, 12:12:04 PM »
Thanks very much michael. With your setup did you have to run an adjustable proportioning valve. On hoppers site they say maybe no valve is worth ago. I don't want to muck around but they are pretty expensive. Did you have any problems with outer front guard clearance?? do you know anyone in brissie who do custom handbrake cables?? sorry for all the questions but you seem a good person to ask.
cheers chris
« Reply #3 on: January 09, 2009, 01:48:20 PM »
59fcwagon, what front brakes are you running, in most cases you can get away without a proportioning valve as long as the rear brakes are not small compared to the fronts. VN rears are a good sized rear brake and would be fine with most HQ to early Commodore era front brakes.
What sort of front stub axles and rims are you running - FC's are well known for front guard clearance problems because of the narrow track and the desire to fit later model brakes and wheels.
59fcwagon
« Reply #4 on: January 09, 2009, 04:53:54 PM »
Hi ken i am running standard hq stubs with hj brakes up front with vn rears (xb master and gemini booster). Front discs have been redrilled to commodore pattern. Like others i havn't made my wheel choice early but i am looking at speedy malibu's 17 x 8 with 215's which are +48mm offset. This will push the outside of the tyre in about 3mm compared with standard 205's with +40. This still however wont be enough. I got a mate who makes polyurethane bushes so am gunna get a couple of taller bump stops made up i think. any problems legally narrowing track a bit?
Chris
« Reply #5 on: January 09, 2009, 06:01:04 PM »
You will have to get the offset on the rim exactly right to fit an 8 inch wide rim in an FC! The fact that you are using a 17 inch diameter allows you to clear the steering arms and other suspension parts.
There are fairly tight rules regarding track changes and you should discuss this with your engineer when you find one. You may have to go back to 7 inch rims.
« Reply #6 on: January 09, 2009, 10:55:05 PM »
The  17'' x 7''  Speedy Malibu's will fit the front with this brake set up is you roll the edge on the guards and use a 205 x 40 x 17 tyre but if you ever scrape a rim the chrome on the Malibu's will flake off they are chromed over a black base and are not very durable l .....FC427....
