August 15, 2025, 06:05:17 PM *
Author Topic: Rear wheel bearings and diff pinion seal  (Read 2057 times)
Wasim
« on: January 05, 2009, 10:15:12 AM »
I'm reconditioning all seals and bearings in the rear end. Having removed all collars and bearings off the axles, I'm about to put the new rear wheel bearings on but without 'belting' them on are there any tips on how to do this easily?? (or do I take them to a workshop to have them pressed on properly?)
I'm renewing the diff pinion seal as well - any clues here would be appreciated.
Thanks, Wasim.
South Australia
« Reply #1 on: January 05, 2009, 11:39:37 AM »
The bearings should slide on - that is why the retaining collar is there. Check to make sure you have the right bearings.
Page created in 0.021 seconds with 19 queries.
