July 29, 2025, 03:10:47 AM *
Author Topic: limited slip diff  (Read 1800 times)
freddyc
« on: October 22, 2008, 08:52:05 PM »
will a limited slip centre fit straight into existing housing and axles etc, regards fred
Townsville North Queensland
« Reply #1 on: October 22, 2008, 09:35:56 PM »
Yes - however you will need to replace one short .stud with a long stud. I mkade a longer stud by welding a longer thread onto an existing stud.
tuffute
« Reply #2 on: October 22, 2008, 09:58:58 PM »
yes as ken said it will it,but u only  change the bolts he is referring to if u put a 2.78 or 3.08 centre in where a different ratio was,as the bottom two bolts are longer on the above ratios
