August 21, 2025, 01:22:12 AM *
Pages: 1 ... 9 10 [11] 12 13 ... 60   Go Down
Author Topic: FCRB30 Wagon  (Read 727530 times)
« Reply #200 on: July 08, 2009, 07:17:34 AM »
Pedro,
That nearly looks easier than cutting the tunnel out, replacing the tunnel with an EK auto unit, then doing the rust repair on the floor.
The bonus is that you will already have all your seat mounts installed and have relocated your hand brake too!
Good luck with it Wink
« Reply #201 on: July 08, 2009, 10:29:58 AM »
Nice work Pedro,
between you and Jason, all this cutting and welding is getting me motivated to start something.
pedro
« Reply #202 on: July 28, 2009, 09:53:21 AM »
Ok, house is booked in for a final, final inspection on fri., if it passes it'll be full steam ahead on the wagon next week, can't wait to get back into it, just went and picked up a bottle of mig gas and some wire and I've finally settled on a colour scheme Grin Grin Grin Grin
                                   Pedro
« Reply #203 on: July 28, 2009, 01:10:43 PM »
Looks good Pedro but what about candy red paint  Grin Grin   mmmm Candy ......FC427....
pedro
« Reply #204 on: July 28, 2009, 01:29:55 PM »
Mmmm candy and chrome Cool Cool, unfortunately i'm not that good a painter Sad.
                                               Pedro
Spinner
« Reply #205 on: August 01, 2009, 12:00:27 PM »
With metal flake black....
« Reply #206 on: August 01, 2009, 01:44:17 PM »
Or black with a red pearl .......Hmmmmm Pearl .......FC427......
Spinner
« Reply #207 on: August 01, 2009, 10:39:09 PM »
Metal Flake black WITH the red pearl.
pedro
« Reply #208 on: August 07, 2009, 05:05:31 PM »
Test fit to make sure everything lines up
The usual rust, expected but still dissapointing
The hardest part, making sure everything is straight, square and has equal measurements then tacking into place, all downhill from here Roll Eyes Smiley Smiley
                                    Pedro
« Reply #209 on: August 07, 2009, 06:20:39 PM »
Good work pedro  one days welding and floor will be done .....Don't STOP ......FC427......
« Reply #210 on: August 07, 2009, 08:05:33 PM »
Good stuff Pedro!!!... You have had your motor in before mine LOL..
NosFEratu
F4+ =^^=
« Reply #211 on: August 10, 2009, 10:38:51 PM »
Good to see you finally be in a position to get to work on it Pedro.  I like your chosen colour combination but please consider painting the roof black too!  Or do black cars scare you?  Wink Cheesy
NosFEratu
pedro
« Reply #212 on: August 11, 2009, 09:30:59 AM »
No but getting the roof straight enough to paint it black does, and also I'm too lazy to wash it all the time Wink, speaking of paint a mate of mine reckons he uses two pack with a normal gun and just puts it in the sun to dry, doesn't sound right to me, any opinions Huh
                                  Pedro
« Reply #213 on: August 11, 2009, 06:00:51 PM »
 Pedro 2K will air dry..... if you put it in a shed close it up and crank up two of those gas patio heaters when the weather warms up a bit you should be able to get to around 45+ deg with out much trouble. that will cure OK  ......I painted my rod with one gas heater and a kero heater and was over 30 deg a few week back when it was 15 deg out side ........FC427........
« Reply #214 on: August 12, 2009, 09:00:16 AM »
I just air dried the ute, but beware of solvent pop.  Took 30 mins to tack off between coats!
last weekend, I just sun dried a bicycle frame I painted.  works OK, but I would have used heaters like Mark suggested if I had some.
Keep up the good work Pedro!
« Reply #215 on: August 12, 2009, 09:16:04 AM »
Ed most 2K even hi fill need minim of 25deg temp  Lips sealed and be very carefull of Temp if using spray polyester if sprayed when to cold can cause adhesion problems   .......FC427.......
utesrule66
« Reply #216 on: August 12, 2009, 12:50:48 PM »
Hi, Smart move leaving the doors on I made the mistake of taking them off and now that the floor has been replaced in my ute I can't get the dam doors to line up again. any tips on how i might rectify this? cheers - utesrule66
« Reply #217 on: August 12, 2009, 01:32:22 PM »
How far out are they from fitting  Huh Huh the service manual should have door aperture measurements for you to check against ........FC427......
pedro
« Reply #218 on: August 12, 2009, 07:34:23 PM »
Thanks for the tips on two pack Mark & Ed, I've done a few laquer paint jobs and a couple in enamel but I've never tackled two pack before, I'm going to give it a go because i like the high gloss finish that is achievable compared to laquer, should i buy a proper gun or is my old gun good enough, if it's going to make a difference i'd rather go the extra $ and get the right one.
G'day utesrule66, are the doors not fitting horizontally or verticaly, or is it in or out, hinges can be bent, holes lenthend but if the opening is too small you have problems, I learned the hard way I bought a wagon project once that someone had already started, the doors wouldn't even fit the openings at all, it was easier just to sell it on than to try and fix it.
                   Pedro
pedro
« Reply #219 on: August 12, 2009, 07:52:12 PM »
Hump done
then rear floor
Took me bloody ages and about five goes before i was happy with that fiddly bit with the hole in it
All tacked in ready to weld.
All fully welded, time to start underneath.
                          Pedro
Pages: 1 ... 9 10 [11] 12 13 ... 60   Go Up
Page created in 0.047 seconds with 17 queries.
