September 09, 2025, 06:48:20 AM *
Author Topic: Brake and Clutch Master cylinders  (Read 1790 times)
Paul In Ireland
« on: April 02, 2008, 04:50:36 AM »
I have to pull out the clutch cylinder as it's leaking - is there a kit for it to renew the seals?
Same for the brakes, I think there is a need to drain and replace the fluid and while i am at it if there was a kit I would redo the master cylinder as well.
Any advice gratefully accepted.
FC0058
Jim Altmann
« Reply #1 on: April 02, 2008, 09:47:17 AM »
Hi Paul
Not quite sure how easy it is to find FE FC parts in Ireland, however I would suggest that you should be able to get the parts you require through any good Auto parts outlet or brake service centre.
Worst case you may need to order the kits throurgh rare spares online store. I can not find my cattledog right now but if you have a look on the website they are not hard to find.
Cheers Jim
nige and Jody
Where do I start?
« Reply #2 on: April 02, 2008, 11:45:28 AM »
G'day Paul,
I would agree with Jim, all that stuff like master cylinders, headlights, switches basically all the period add ons was usually made for other markets as well.  I would take my master cylinder into the brake place or your equivalent of 'REPCO' and get them to match it.  Failing that another idea would be to get someone here to source the stuff for you and send it over  Smiley  with direct deposit and PAYPAL there are certainly ways and means.
Nige
FC225 (in progress), FB215 (waiting), EJ229A (go'er)
