September 06, 2025, 09:57:25 PM *
Author Topic: what booster and master cyl works best with 4 wheel disc brake??  (Read 3442 times)
sexyfc
John greco
« on: January 23, 2008, 12:06:20 AM »
Hi, Just bought a nine inch out of an HJ with disc brake, i'll be running a small block in my FC. With the existing hr front end what caliper and rotors should i run on the front, and what booster and master cyl??
Project started 16/01/08.
« Reply #1 on: January 23, 2008, 06:01:47 PM »
I also run 4 wheel disc brakes on my Ute and use a VH v8 Commodore booster and a 1'' master cylinder 4 piston callipers all round and 295mm Commodore front rotors on HZ stubs and all works great .........FC427.........
« Reply #2 on: January 23, 2008, 11:22:06 PM »
For simplicity sake run HZ front brakes with any booster from a medium to large car, and a 1 inch diameter master cylinder.
You can get much flasher than this and the possibilities are almost endless depending on how much cash you want to spend and what size tyres you will be running.
sexyfc
John greco
« Reply #3 on: January 24, 2008, 08:52:11 PM »
So the HZ Stub axles will fit straight on to the hr front end? And if so will that also lower the front like HQ stub axles.
« Reply #4 on: January 28, 2008, 07:04:39 PM »
Stub axles from HK right through to WB are identical. Make sure you use HKTG steering arms though.
Regards  Ken
