September 02, 2025, 09:22:21 PM *
Pages: 1 ... 4 5 [6] 7 8 ... 10   Go Down
Author Topic: My new project  (Read 183308 times)
« Reply #100 on: October 15, 2010, 06:50:38 PM »
Looking good.
front end looks great i purchased mine today was going to have a go at my own the the whole enginnering proccess scared me so i just bit the bullet and ordered one.
i also ordered a 322mm rotor and calliper kit off a mob in qld.
I am going to run a manual VL rack as i like my steering a bit on the heavier side.
You would think for the money you would get a modified set of tie rod ends.
Love your colum keep going its a credit to you.
Keeps us all enthusiastic and wanting to work on our cars.
Pete
« Reply #101 on: October 15, 2010, 07:38:28 PM »
That does look great Jack,
I am hoping to have the ute home next week to start on it again.
Where did you get the intermediate shaft made? I also have to get the column shortened a little as well.
When I get it here I will show some photos as well.
FC_fer_me
baby boomers luv FC's
« Reply #102 on: October 15, 2010, 07:55:53 PM »
Hi JB, I made the intermediate shaft out of a VL shaft and a VS shaft. I removed the VL top from the damper and fitted it to the VS shaft after removing the VS top coupling. I then cut the shaft to length and got a local engineering firm to sleeve, pin and weld the joint. Hope this makes sense. you can see the sleeved joint in the 5th picture. Cheers ,jack
Chuck
Finished!
« Reply #103 on: October 16, 2010, 10:17:21 AM »
I like it, I like it very much!
« Reply #104 on: October 16, 2010, 10:43:36 AM »
Jack,
Great work, it's coming together very well!
TTV6FC
« Reply #105 on: October 17, 2010, 10:25:04 PM »
Nice work Jack,all these photos will help to make my next one easier... Wink Jamie.
FC_fer_me
« Reply #106 on: December 28, 2010, 12:12:12 PM »
Hi all, well with Xmas out of the way I have been getting stuck into the car. Have had the fuel and brake lines done and fitted the motor. It all went quite well apart from the right side extractors, I had to cut the bottom off them to get them in. I will get that side custom made further down the track. I think the extractors were made for use with a HR frontend. The engine wiring loom has been connected up and now I've got the job of shortening the wires to the ECU, that should keep me out of mischief for a while! I intend to get all the mechanicals and wiring done before I move back on to the bodywork. Til the next update, Cheers, Jack.
« Reply #107 on: December 28, 2010, 12:51:41 PM »
Looking good now Jack, another step closer to having it back on the road!
Keep up the good work Wink
ehsv6
« Reply #108 on: December 28, 2010, 08:30:30 PM »
I wouldn't shorten them, the electronic ignition has a standby system that looks for pulse fed back via the earth lead from the module mounted on the engine (brief description, you can read how it works in the manual) you may upset that, I'd coil up the excess around around the inside of the dash.  Cheers Keith
« Reply #109 on: December 30, 2010, 08:41:37 PM »
Looks like you are having the wiring fun that I have ben having. I have been using heat shrink, shortening the wires, overlapping in a finger join style and then wrapping the joining in the same wire before soldering. No dry joints that way.
Have fun
TTV6FC
« Reply #110 on: December 30, 2010, 10:10:13 PM »
Hmmm,pulse sent back from earth lead?Yes I know current flows from earth to positive but where does a pulse originate if coming from earth???  Huh
FC_fer_me
« Reply #111 on: December 31, 2010, 07:55:44 PM »
Hello JB, what I did was remove one pin at a time from the connectors ,shorten the wire then resolder it back on the pin and re-insert it into the connector. This way you have no joins in the wiring .Cheers ,Jack
jack_fc
SouthWest Coast, Victoria
« Reply #112 on: January 09, 2011, 08:10:25 PM »
Really starting to look the goods now, Jack  Cool
Can we assume the blue on the engine cover will be one of the body colours?
Regards to you and Chris
cheers, jack n rita
FC_fer_me
« Reply #113 on: January 10, 2011, 08:12:58 PM »
Hi Jack, hope you and Rita are both well, I haven't seen you on the forum for a while. The engine cover is a GMH blue engine enamel. It's not one of the body covers but any blue is a good blue hey! Must get down to pick up that radiator soon as you can see I am getting close to fitting it. Hopefully in the next month when things quieten down a bit at work. Cheers for now, Jack n Chris
jack_fc
« Reply #114 on: January 10, 2011, 08:39:18 PM »
Jack,
Radiator is still in the shed waiting for you, there's beer in the fridge and a spare room  Smiley
All's well  this end (except for the FC, but that's another sad story  Cry)
Looking forward to catching up with you and Chris soon.
cheers, jack
pedro
« Reply #115 on: January 15, 2011, 04:27:52 PM »
Looking flash Jack, everything fits well and looks neat and tidy, wish I'd gone down the V6 road myself now.
                   Pedro
« Reply #116 on: January 15, 2011, 07:24:08 PM »
Deep down no you dont.
It will smoke a V6
LOL
pedro
« Reply #117 on: January 15, 2011, 07:53:26 PM »
It will smoke a V6
Weel I must admeet I do like the idea of that part Sen'or Grin Grin
           Pedro
FC_fer_me
« Reply #118 on: March 15, 2011, 05:48:14 PM »
Hi guys, time for another update. Nearly all the mechanical work has been done, radiator fitted ( thanks Jack ), most of the wiring has been done, just a few loose ends to tie up , ( like JB I'm giving the wiring part a rest!). Have just trailered the car to the exhaust place to get the extractors and exhaust sorted. Moving house next week so it will be much easier to move the shed stuff without the car in it! Won't have much time to do any work on it for the next couple of weeks so it was a good chance to get the exhaust done. Cheers, Jack.
Back on it's wheels (not the wheels I'm using just some old wheels off the donor car)
VT floor shift fitted (mongrel of a job, had to cut a fair bit of the tunnel away!)
Computer fitted and wiring shortened.
Battery fitted in boot using original battery tray.
Radiator and power steering reservoir fitted.
« Reply #119 on: March 15, 2011, 06:05:43 PM »
Is looking very good.
Moving sux slow everything down so good luck.
Pages: 1 ... 4 5 [6] 7 8 ... 10   Go Up
Page created in 0.037 seconds with 15 queries.
