August 25, 2025, 08:23:34 PM *
Author Topic: HR wheels vs FE wheels  (Read 1866 times)
Sheriff
FEs rule!
« on: December 29, 2007, 07:22:08 PM »
Are HR 13" wheels different to FE Wheels?  I bought a set of HR Premier wheel trims thinking that they would look pretty smick on my car only to find that they don't want to go behind the hubcap retainer on the wheel. I would have to get the weights placed on the back of the wheels anyway.  I'd assumed that all the wheels would be the same. *&%@**.   Ta.  Mike.
Spinner
« Reply #1 on: December 29, 2007, 07:45:22 PM »
Yes, they are different.
HR (and later HD?) rims have the following measurements.
13" diameter.  4½" width.  3½" back.  1" front.
FE to EH (early HD?) rims have the following measurements.
13" diameter.  4½" width.  3" back.  1½" front.
Front & back dimensions are taken from the flange mount to the bead well.
Both rim types are different in how the centre is fitted to the rim too.  HR wheels are welded in, FE-EH wheels are riveted together.  The HR centre is pressed with a round shaped opening for air flow whilst the FE-EH centre is pressed with a raised (depressed?) relief giving a rectangular opening.
Brett
Sheriff
FEs rule!
« Reply #2 on: December 29, 2007, 07:50:04 PM »
Thanks, Brett.  Is there any problem using HR rims on a FE?    Mike.
« Reply #3 on: December 29, 2007, 08:40:19 PM »
Yes there is, you will find that the FE brake drums have a raised section which fouls on the HR rims. When you tighten the HR rim the brake drum bends and causes brake grabbing
Page created in 0.024 seconds with 19 queries.
