August 04, 2025, 11:17:42 PM *
Pages: 1 [2]   Go Down
Author Topic: Grant's Fe Project  (Read 26260 times)
fe1957
Turbo Charged
« Reply #20 on: April 09, 2012, 07:16:16 PM »
Ok, finally completed turbo manifold today, boy am i sick of grinding  Tongue
Certainly took a bit to get it to sit with good clearance all round.
Turbo is  gt35 size, 45 mm turbosmart hypergate,steam pipe is 1.4 inch , 80 mm throttle body yet to weld to manifold. head is a yella terra steel 12port
I have now modified sump for external oil pump feed and drilled block for external feed, so now i can reassemble engine. Engine will be grout filled to bottom of waterpump, full stud kit,girdle, roller cam
Off to get heat coated
Later in week i will dummy fit intercooler and radiator so that i can set up inlet and outlets for turbo Smiley
And then on to dump pipe.
OFE570
« Reply #21 on: April 09, 2012, 07:28:57 PM »
That exhaust is gunna be tight out the back of the turbo maybe just remind the passenger about the glow on the floor.. Grin
Looks smick  gunna take some chuffing to spool that turbo thats a monster.
fe1957
Turbo Charged
« Reply #22 on: April 09, 2012, 07:44:08 PM »
Hey Pete, the photo does give an illusion, will fit a 3inch 90 fairly easy yep, will need to run a shield to stop getting toasty.
Turbo wise it runs a smaller housing than profc so i am hoping it will be ok
grant
OFE570
« Reply #23 on: April 04, 2013, 04:21:36 PM »
Bump, how's this one coming along?
fe1957
Turbo Charged
« Reply #24 on: April 08, 2013, 06:46:23 PM »
Hi glen still going have got a little sidetracked with a hotrod project  Tongue
Not mutch left on the body and engine some final mods  to make roller cam , lifters rocker geometry all work and big $ purchase of ice system .
I will post some current picks
Cheers grant
OFE570
Ol_Girl_58
getting there...
« Reply #25 on: June 29, 2014, 05:49:36 PM »
Bump! What's happening with this project?
Can you provide some info on the ICU you're using?
Josh.
fe1957
Turbo Charged
« Reply #26 on: July 07, 2014, 06:52:51 PM »
Josh.
Hi josh, I will take a few photos by the end of the week. Ecu is microtech, I can tune these fairly easy with 1200 cc injectors, the ignition is a 7amp ice unit with 16 volt booster through a standard locked electronic distributor. Just doing body work atm but should also fire up engine within next week as the alloy welding is now complete. Phew
Grant
OFE570
Re:
« Reply #27 on: December 03, 2014, 10:48:46 PM »
Hey Grant, howz going. Do u have tapatalk yet? What's happening with the 57?
Pages: 1 [2]   Go Up
Page created in 0.035 seconds with 17 queries.
