June 18, 2025, 04:13:39 AM *
Author Topic: Brake line piece  (Read 3105 times)
Hewart
Holden on forever...
« on: July 06, 2007, 10:58:50 AM »
G'day guys....
I'm after a small bit for my brake line..... It's this bit below. This is a new one, but it doesn't screw in (wrong thread), so I need an original one.... (I did source a new piece of pipe, but they replaced the both nuts with new ones, when I only needed one new nut and one old)
Either that, or just the whole this brake line piece if that's easier (on the drivers side - from wheel cylinder, rubber hose, then this metal brake line pipe)
and screws into here on the subframe...
Les...
fccool59
« Reply #1 on: July 06, 2007, 06:49:05 PM »
did you make sure the guy @ the brake shop understood it was imperial.
some places have metric nuts with imperial threads and some have imperial nuts with imperial threads.
I got mine from B&R brakes in blacktown, everything seems to screw up so far.
« Reply #2 on: July 06, 2007, 09:20:32 PM »
Les,
You need to do it yourself to get it right
looking at the pic, they did an awful job of bending the tube and in addition got the nut sizing wrong.
if you get some nuts I may have some leftover tube which is long enough. I can  make up a piece for you.
Fast_Eddie
« Reply #3 on: July 07, 2007, 12:08:08 AM »
Les,
Make sure you haven't threaded the brass connector - I recently did this myself with an incorrectly supplied metric fitting.
I found that the metric thread would screw in to a point, and then it threaded the brass junction block which is much softer.
Looking at the pictures, I fear you may have done this, based on the fact that the gold zinc plating has been stripped from the bottom of the thread on the pipe nut.
May be worth getting another junction block and bench testing each female thread rather than risking a leak at the existing junction block.
Hewart
« Reply #4 on: July 11, 2007, 08:50:24 AM »
That was part of the problem, one end needed to be imperial, and the other metric :-/ Apparently the old one crumbled in his hands mid-way, so he scooped it all up and chucked it!
Unfortunately I may have helped with the awful bending job when it didn't fit the first time  Cry   I'll keep you in mind if I need to reshape something myself, thanks Ed!!
Thanks Ed, yes, I'm a bit worried about it myself, but fingers crossed it'll be OK still...... I really can't test it until I track down the right bit...
Les...
« Reply #5 on: July 12, 2007, 07:01:19 AM »
Les, did you get this bit of pipe?  I have an original one here or I can make you a brand new one with new fittings. If you need a new one just tell me what fittings you want either end and I will do it.
Page created in 0.044 seconds with 19 queries.
