September 05, 2025, 03:00:01 PM *
Author Topic: heater hoses  (Read 2471 times)
Phantom
« on: May 26, 2007, 04:37:28 AM »
G'day all, another dumb question , which heater hose do i put the heater tap on my red motor? the hose wich comes out of the top or the bottom of the engine?
                           Cheers Rusty
Bogans rule
« Reply #1 on: May 26, 2007, 05:37:13 AM »
Neither.  Wouldn't that block all water into (or out of) the radiator? Shocked
The tap is usually fitted to the water pump.
Phantom
« Reply #2 on: May 26, 2007, 05:54:47 AM »
I didnt explain myself i suppose , what heater hose do i put the tap ? i have two outlets from the water pump a top one and a bottom one , which hose do i put the tap on or doest it matter?
                   Rusty
Bogans rule
« Reply #3 on: May 26, 2007, 07:18:09 AM »
As far as I am aware there is only one heater hose outlet on a red motor water pump and it exits from the top just behind where the radiator hose attaches. On a new water pump it is usually blocked and you have to drill through to make it operational.  There are 2 outlets just above this in the thermostat housing which are for the manifold heater - are you getting confused with these two?
Page created in 0.029 seconds with 20 queries.
