September 05, 2025, 04:48:59 PM *
Author Topic: V8 economy  (Read 2218 times)
Rev
« on: March 30, 2007, 11:52:06 PM »
Hi guys,
Some of you are aware that I'm in the market for an FE or FC up to $10K.  No luck so far.  But in the process of hunting, I've come across an issue I need some advice on.  I'm looking for something that's been modified.  I've always thought in terms of a 186 or something similar as replacement to the old sideplate.  But I've seen a couple of cars that are running small V8s, and one of them was on gas.  Just on a fuel economy point of view, what kind of mileage can I expect from a small block V8 on gas?  (and can you talk to me in mpg, I still can't get my head around km per litre)
Thanks for your help,
Rev
« Reply #1 on: March 31, 2007, 05:14:04 AM »
Hey Rev,
not sure if V8 and economy belong in the same sentence..
not so bad if you have a light foot i spose, good gearing, overdrive, and EFI...
figure on 16 - 20L/100kms (city)
or around 15L/100 (highway).
that's with a 1.00 final ratio on gearbox, 3.25 diff gears and EFI.
im fitting overdrive to reduce the consumption and adding a lock up convertor.
sorry about the L/100 thing, i cant get my head around MPG.
hope this helps.
these are petrol figures, LPG uses about 20% more.
if you're in the marklet for a V8 have you seen Ben's (revhead fc) 350 HR for sale?
Rob_FE_56
« Reply #2 on: April 03, 2007, 10:56:10 PM »
  G'day Rev,
Was always keen on running a  carbied small block chev in my fe but excessive fuel consumption killed that idea.
Changed the plan to an injected 5 litre holden with a 4l60 box ( about 30% overdrive).
I am running 2.75 diff gears with 13" wheels which brings me back to about 2 grand at 60 mph with the o/d auto. Pretty close to standard commodore gearing.
With any luck we should get somewhere around 32-34mpg out on the highway which will work in with the plan to use it as a daily driver if need be.
The engine is stock bar the addition of a factory 195kw VS  HSV chip and a very mild camshaft chosen to suit it.
Minus power steering pump and with a decent exhaust should get a bit over 200kw and a shed load of useable torque.
The extra initial cost of an injected engine will soon repay itself in fuel savings if your'e keen to run up a few miles.
Injected engines are becoming real cheap these days, a vn 5.0 L went for $900 on ebay recently!
Cheers, Rob.
« Last Edit: April 03, 2007, 11:00:09 PM by Rob_FE_56 » Logged
