March 29, 2024, 01:22:13 AM *
Pages: 1 [2] 3   Go Down
Author Topic: Adjustable Boot Spring Posts  (Read 75575 times)
Steve Jackson
« Reply #20 on: March 21, 2011, 12:45:30 PM »
Thanks to Greg and Ret, done all done ..... eight hours later ....  :oops:  I think I could do it in two hours now I know the right steps.
Step one ... grind the back off the broken lug almost flat to the support. ........  I drilled through from the inside for hours and used many drill bits. The drill spun out of my hands a few times  :cry:  Ouch!  It took ages stepping up through the sizes and burning bits. I then went to Bunnings and purchased three very expensive dtill bits in high tensile. With a bit of cut compound on the tip, this worked well. After drilling, I found out the thread on the new spring bolt was not long enough  :roll:  :oops:  So then I ground the back of the old Lug as per step one ...  Cheesy
Step two, drill the hole for the bolt to go through. The biggest drill bit I purchased was a 1/2" The thread needs a slightly bigger hole.
Then it is easy from there to adjust the spring tension with a long Hex Key and a 7/8 thin spanner. This is a great method as you don't need a spring tool and this avoids looking fingers.
I believe FE-FC original lugs are easier to remove. I will find out when I tackle the FC 215 this weekend  Shocked
Steve
Before
After
Without nasco broom handle .....
Factory Paint FB and EK's wanted.
Maco
« Reply #21 on: March 21, 2011, 05:43:24 PM »
Hi Steve,
Where abouts in Penrith are you, maybe I can help when you attack the next one.
Better in Green
ACE
DOH!!!!!!!!!!!! !!!!
« Reply #22 on: March 21, 2011, 06:05:17 PM »
G'day Steve,
You just clamp a set of vice grips horizontally on the lug and bend it back and forth and break it out of the panel...no drilling or grinding Wink
ACE  Cool
Steve Jackson
« Reply #23 on: March 21, 2011, 06:31:17 PM »
Hi Steve,
Hi John, I am in Abel Street. Ret came out on Saturday. Thanks for your offer of assistance. The FC is at home in Armidale, unless you want to pop up there, I will have to find another job for you.  Wink
Steve
Steve Jackson
« Reply #24 on: March 21, 2011, 06:33:12 PM »
G'day Steve,
ACE  Cool
Hi Ace, I tried that and that's why I thought FE-FC's may be a little weaker. I even tried to chisel them off without luck  Huh
Steve
ACE
« Reply #25 on: March 21, 2011, 10:42:11 PM »
G'day Steve,
I've done the same to a EK and don't recall it being any more difficult Huh
ACE Cool
Steve Jackson
« Reply #26 on: March 21, 2011, 10:51:43 PM »
I will sure be trying that again on the next one  Embarrassed
While I was doing it, I thought it can't be this hard  Angry
Thanks for your help Ace, Smiley
Steve
« Reply #27 on: March 25, 2011, 07:20:30 PM »
Hey Steve,
Sorry to hear you had so much trouble. I've seen them spot-welded (presumably after they've broken), and obviously in that case they won't come out without a fight.
I can only hope the FC proves a little more straightforward... Undecided
Steve Jackson
« Reply #28 on: March 25, 2011, 08:09:18 PM »
Hey Steve,
Howdy RET, had a fiddle with the FC yesterday. The original pin is on one side and one half broken off. The other side had the big ugly bolt, so only one to snap off Smiley Unfortunately, I left the two new pins at the warehouse  Embarrassed
Steve
Maco
« Reply #29 on: March 26, 2011, 10:00:11 AM »
Hi Steve,
Give me a call when you are back in Penrith.
Better in Green
black57
feratrod
« Reply #30 on: November 04, 2011, 01:52:19 AM »
Ret, any more left or coming soon?
FE Standard rat rod
MG Midget
1965 GSM Dart - ex race car
1948 Singer 9
And a couple of Cyclekarts underway
« Reply #31 on: November 04, 2011, 01:00:04 PM »
Hi black57,
The last set went about a week ago. A new batch is being made at the moment, should have them before Christmas, hopefully.
« Reply #32 on: November 04, 2011, 05:45:57 PM »
Hi Ret, you can put me down for a set as well.
Thanks, Jim
black57
feratrod
« Reply #33 on: November 04, 2011, 07:11:08 PM »
Awesome. Im up for some. Just let me know how to pay etc. Pm if you like.
Pink.
FE Standard rat rod
MG Midget
1948 Singer 9
« Reply #34 on: February 16, 2012, 10:33:46 AM »
I have sets of these boot pins in stock and available now. Send me a PM if you'd like to order a set or two.
collecta
« Reply #35 on: September 24, 2013, 07:33:11 PM »
  Hi RET are these still available?
 Scott
« Reply #36 on: October 08, 2017, 04:37:35 PM »
I do have a small number of these pins currently available. $48/set, PM me to arrange.
PVB
« Reply #37 on: December 13, 2017, 04:08:07 PM »
Got mine rhet.. willput themin after Christmas .. they look good
black57
feratrod
« Reply #38 on: February 07, 2019, 07:45:53 PM »
Hi Ret. Been a while, but are there any left?
I bought some years ago and now I'm finally ready to put them in they are nowhere to be found...
FE Standard rat rod
MG Midget
1948 Singer 9
« Reply #39 on: February 08, 2019, 11:11:26 AM »
Sure, I’ll PM you banking details etc.
Pages: 1 [2] 3   Go Up
Page created in 0.044 seconds with 21 queries.
