August 27, 2025, 05:17:52 AM *
Author Topic: problem solvers required  (Read 3861 times)
Rabbitoh
FE - 'King of Cars'
« on: October 25, 2006, 08:53:33 AM »
After installing new points, plugs, condenser, dizzy cap &  h. t. leads I had my wagon's motor running sweetly. Then I hooked up a timing light to check the ignition timing. Well now the motor will only crank over one or two (very slow) revs and generally impersonate a car with a very flat battery. I have 12.5 volts at the bat. terminals and a fat spark flies from the end of the coil/dizzy cap ht lead when held near motor? Suspected starter motor/solenoid, but replaced both with the units from my dismantled sedan (working when removed from car) with the same results. I need help Sad
Bunnies' 22nd in 2026?
HARKO
« Reply #1 on: October 25, 2006, 09:42:54 AM »
Engine to chassis earth lead  Grin
Or starter to earth maybe.
Process of elimination .
Shayne
Just Cruisin'
« Reply #2 on: October 25, 2006, 09:45:31 AM »
I'm with Harko, try the earth straps first.  What about leads onto starter solenoid?
Good luck.
fccool59
« Reply #3 on: October 25, 2006, 10:17:07 AM »
I am with harko too, I just had the same problem with my wifes car, I was going to pull the starter out but after the car sat out the front for a week while my wife drove my ford I was sitting on the toilet and came up with a idea to check the earth strap and sure enough it started.
SRVLIVES
« Reply #4 on: October 25, 2006, 11:56:07 AM »
Can I be with Harko too! Grin
Although, I can't imagine there's anything left to drink.... Sad
Russ
mmm dohnuts
« Reply #5 on: October 25, 2006, 12:40:46 PM »
when the spark is to far advanced it has that problem seen it heaps Grin
Rabbitoh
FE - 'King of Cars'
« Reply #6 on: October 26, 2006, 08:36:32 PM »
Harko, thanks for that. Checked the battery to engine earth strap, is this the one you meant? Is the Starter to engine earth the metal strip connected to the terminal nearest the engine?
Will also check the spark advance, Russ, and the solenoid leads Shayne. Will also check ignition/starter switch terminals & leads, (I'm getting a bit desperate).
Chris
Rabbitoh
FE - 'King of Cars'
« Reply #7 on: October 31, 2006, 01:13:14 AM »
Well even though my volt meter said I had over 12 volts at the battery, I should have been testing it while it was under cranking load, shouldn't I! (Yep, you guessed it, dud battery).
Thanks for all you suggestions anyway. A life lesson for young players I suppose:-[
Rabbitoh
FE - 'King of Cars'
« Reply #8 on: October 31, 2006, 01:15:50 AM »
Oh, forgot to mention, this was discovered after I had re-built my suspected, but quite innocent starter motor, Oh dear....
