Technical Board => Restoration Help => Topic started by: Glenn 'Stinky' Stankevicius on January 05, 2024, 06:31:23 PM
Title: FE Standard front bench seat.
Post by: Glenn 'Stinky' Stankevicius on January 05, 2024, 06:31:23 PM
Of all of the FE/FC front bench seats that I have recovered the backrests have always had side openings with sleeves that are held together with an internal zig-zag wire and hog rings, this is then covered with the plastic trims.
I currently have an FE Standard seat in my workshop that has no side openings and no side plastic, is this factory standard or am I looking at a very old custom seat re-trim?
Title: Re: FE Standard front bench seat.
Post by: ardiesse on January 05, 2024, 06:43:21 PM
Glenn,
The front seat squab cover on Standards has no side opening.  The seams have piping (if that's the right word) starting at the bottom of the sides, going up, continuing across the top of the seat and down the other side.
I can send you a photo or two of my FC's front seat, if that'd help.
Post by: Glenn 'Stinky' Stankevicius on January 05, 2024, 07:10:41 PM
Thanks Rob, I have since found this listing with pictures showing the backrest/squab.
https://www.grays.com/lot/0001-20081947/classic-cars/1957-holden-fe-sedan
