Technical Board => General Technical => Topic started by: Pahs59 on August 26, 2020, 07:28:03 PM
Title: Early holden fuel tanks fe fc fb ek
Post by: Pahs59 on August 26, 2020, 07:28:03 PM
Does anyone know how they joined the top and bottom sections of the fuel tanks together, were they seam welded? Spot welded?
Title: Re: Early holden fuel tanks fe fc fb ek
Post by: mcl1959 on August 27, 2020, 08:41:34 PM
I believe it’s some sort of a rolling spot weld that seals the join. It’s impossible to get apart From my experience.
Post by: Pahs59 on August 27, 2020, 08:57:27 PM
Thanks ken,I thought they may have been seam welded like you say two rollers doing a continuous weld...I’ll still put my two tanks that I thought I might have been able to make one good one up in the rafters...I can’t bring myself to throw them out
Post by: Diamond Dog on August 28, 2020, 08:10:41 PM
I'm no expert but maybe lead wiping or brazing could be an option.
Post by: mcl1959 on August 28, 2020, 08:54:54 PM
It wasn’t so much the putting back together, but the getting the tank apart without cutting the seam off
Post by: Pahs59 on August 28, 2020, 09:22:39 PM
I have two fc wagon tanks one has a good top and one a good bottom I was going to make one out of the two..maybe carefully unpick the good bits...oh well a rainy day job I’m thinking
Post by: Diamond Dog on August 29, 2020, 10:28:39 PM
Covid project ?
Post by: Errol62 on August 29, 2020, 11:34:43 PM
Seems obvious to me. Just cut and grind away the dud section from either tank. It was common to use volumes of lead solder to fill pin holes in the tops of rusted tanks. plug weld the two good sections together and seal with lead as suggested.
