Technical Board => General Technical => Topic started by: JohnBM on February 27, 2020, 03:49:49 PM
Title: Front wheel bearings
Post by: JohnBM on February 27, 2020, 03:49:49 PM
I have a June (mid year) built FE , are the front wheel bearings the same right & left ? Also would anyone have the the original part no . or an equivalent no from a bearing supplier . I know I can the no off the ones on the car , but would like purchase them before I start taking things apart . Cheers John
Title: Re: Front wheel bearings
Post by: mcl1959 on February 27, 2020, 05:01:10 PM
They should be the same left and right, but they may not be. Front wheel bearings changed mid FE. Early FE had FJ wheel bearings and late FE had FC onwards bearings.
If I were you I would take them out and check before buying.
Post by: ardiesse on February 27, 2020, 06:23:58 PM
John,
f.y.i.: the inner diameters are 0.6875" i.e. 11/16" i.e. 17.47 mm and 1.125" i.e. 1-1/8" i.e. 28.58 mm for the earlier bearings, and
0.750" i.e. 3/4" i.e. 19.05 mm and 1.25" i.e. 1-1/4" i.e. 31.75 mm for the later bearings.
Original part numbers:
Early front wheel inner bearing (ID 1.125", OD 2.375"): 7408849
Early front wheel outer bearing (ID 0.6875", OD 1.750"): 7408852
Late front wheel inner bearing (ID 1.250", OD 2.328"): 7413406
Late front wheel outer bearing (ID 0.750", OD 1.781"): 7413409
Post by: JohnBM on February 27, 2020, 11:36:28 PM
Thanks very much , Ken & Rob , I do recall way back there was a problem with the bearings . & I had to take them back to get the correct ones . I worry too much & im sure the ones on the car will be ok . I try to pre/empt problems . Ie prevention is better than the cure . Especially with our fourth Nullarbor trip coming up . Cheers . John
