rear leaf springs.. is this right ?
Started by coolaride, April 26, 2006, 08:39:53 PM
coolaride
hi
this doesnt look right to me ..
the leaf that hangs underneath on both sides is why i`m asking this question .
i thought they were all connected together .
both sides look to be done the same..
would this be an add on at some stage ?
did early wagons have a different set up ?
maybe fe wagons had this set up ?
or is this normal .. and i`m waisting peoples time ?
hope someone can help
c - ride  :)
coolaride,
my wagon has no spring like pictured.
is it a helper spring?
cant remember how many leaves I have, will count later.
graham_fuller
Hi Cooleride,
These are called uplifting springs often used when towing to stiffen up the suspension. They can also be used if the springs have sagged. I have a set on my car that go the full length of the leaf springs,  I also have spare set just like yours.
Graham
HAD 708
I Know them as override springs. I have a set fitted to my sedan that were dealer fitted from new as the original owner used to Tow a lot. They are a very good option even more so for wagons as they tend to need as much rear end support as possible.
Brett
Brett Gillard
coolaride
hey there
thanks for the replys guys..
c-ride  :)
