Pushrods?
Started by deano, June 15, 2005, 07:51:09 AM
deano
Hi Guys,
Thanks for the help with the rocker removal removed the pushrods from my 138grey and found that 4 are slightly bent, can I still source new ones or can I staighten them myself?
cer444
If you have a Grey engine second hand pushrods will be the go.
Be careful with Red motors they have 3 different length pushrods so get the right length.
Pushrods are not worth the effort for straightening!!
ACE
.....and grey motors have 2 different length pushrods ;)
ACE  8)
cer444
  "You learn something new everyday"
I didn't know Grey's had 2 different length pushrods.
Thanks ACE.
             Regards Aaron
PS..... Why did they have 2 different lengths? I know Red's had different lengths for different block heights/Rocker gear (I think)?
gp
Don't know WHY they changed them, but the lifters are also 2 different depths. ???
Graham
julius
The reason why is because they have 2 different depth cavitys for the pushrods to go into the lifters in the grey.
Julius
graham_fuller
Pushrods are easily straightend as my previous motor bent 2 and I successfully straightend them in a vice with soft jaws and a hammer. Worked fine for 6 years until the engine was rebuilt.
Graham
FCwagon
Grey's have 2 different lengths because the early engines did not have a drain hole in the cam follower and oil that sat in them sludged up easily and also couldn't drain out at oil change intervals. All up they hold about 1/2 pint.
Straightening pushrods is a temporary fix unless they are done perfectly. Because they're expected to rotate in operation.
cheers,
Leigh
Red & white is alright
Tumbles
I believe there are a couple of differn't width rods as well, are they relative to the length?
Tumbles
