another blinker question
Started by smithy, December 02, 2004, 01:28:11 AM
smithy
with the front blinkers on a FC
1/ is there a earth wire or is the "blinker bulb holder" earthed to the body?
2/ is there a bracket or clip to hold the assembly (bulb etc) to the body???? and if there is a clip does anyone have a couple of spares please ;D
thanks heaps
dean
FC-V8
Dean
   The blinker bulb holder is earthed when it is pushed in to the body of the blinker which in turn is earth by the guard. No clips are required as the bulb holder is a push in type the same as the rear tail lights.
Glenn
0401-065-201
smithy
thanks for that glen, guess i need some new bulb holders as mine just seem to bounce around a hell of a lot.
dean
FC-V8
Dean
        If it is the bulb it self that is bouncing around you could have broken springs inside the bulb holders as they keep the bulbs & the connection tight in the holder.
Glenn
0401-065-201
smithy
nah glenn its the whole body thats moving, seems the hole is larger than the holder. mind you they do look like original items. might have to just get new /newer ones.
thanks for ya help
Martin
Try spreading the claw-like spring clips before you go out & replace them.
Martin
Marion.  South Aust.
Ebay user id:  lewis1411
